Is there a command available to "unhide" the mouse cursor...
  • Is there a command available to "unhide" the mouse cursor...
    ...after RR has loaded?
    Generally, I like having the mouse hidden, but some embedded apps, such as my OBD program, just needs a mouse/keyboard combo.
    Is there a way to unhide it, then hide it again during runtime?
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    You can do it with an easy autoit script with iniRead and change the lines
    Hidemouse=true
    Hidemouse=false
    Let me know if you need it, I can write it up for you.
      I'm familiar w/ the IniRead & IniWrite function in AI.
      I need something that will unhide the cursor when I need it, then command it to hide when I'm done.
      Is that something you could help me out with?
        NVM.
        Finally found an existing script in the AI forums that changes the cursor runtime.
        Code:
        Global Const $OCR_APPSTARTING = 32650
        Global Const $OCR_NORMAL = 32512
        Global Const $OCR_CROSS = 32515
        Global Const $OCR_HAND = 32649
        Global Const $OCR_IBEAM = 32513
        Global Const $OCR_NO = 32648
        Global Const $OCR_SIZEALL = 32646
        Global Const $OCR_SIZENESW = 32643
        Global Const $OCR_SIZENS = 32645
        Global Const $OCR_SIZENWSE = 32642
        Global Const $OCR_SIZEWE = 32644
        Global Const $OCR_UP = 32516
        Global Const $OCR_WAIT = 32514
        ;~ _SetCursor(@WindowsDir & "\cursors\3dgarro.cur", $OCR_NORMAL)
        ;~ _SetCursor(@WindowsDir & "\cursors\3dwarro.cur", $OCR_NORMAL)
        _SetCursor("C:\Program Files\Road Runner\normal.cur", $OCR_NORMAL)
        ; $s_file - file to load cursor from
        ; $i_cursor - system cursor to change
        Func _SetCursor($s_file, $i_cursor)
           Local $newhcurs, $lResult
           $newhcurs = DllCall("user32.dll", "int", "LoadCursorFromFile", "str", $s_file)
           If Not @error Then
              $lResult = DllCall("user32.dll", "int", "SetSystemCursor", "int", $newhcurs[0], "int", $i_cursor)
              If Not @error Then
                 $lResult = DllCall("user32.dll", "int", "DestroyCursor", "int", $newhcurs[0])
              Else
                 MsgBox(0, "Error", "Failed SetSystemCursor")
              EndIf
           Else
              MsgBox(0, "Error", "Failed LoadCursorFromFile")
           EndIf
        EndFunc  ;==>_SetCursor
        Did a quick test to see if works in RR and it does.
        Going to elaborate it a bit to allow to hide and unhide the cursor now.
        Thx anyway.
          Thats pretty cool, what are you using to tell it to hide the cursor though? The script above lets you chance it to another one, but not hide it from what I can see.
          My Fiero Build Thread
            Yeah. That was just a straight cut and paste from the AI forums that allows you to set a cursor.
            Here's what I put together to be used in RR to use the .cur files already in the RR directory:
            cursor.au3 code:
            Code:
            #comments-start
            Hides/Unhides mouse cursor during runtime
            Author: Sal R.
            #comments-end
            ;Open coms w/ RR
            $rr = ObjCreate("RoadRunner.sdk")
            ;rr's install directory
            $rrpath = $rr.getinfo("RRPATH")
            ;Get command info from RR
            $viewOpt = $cmdlineraw
            Switch $viewOpt
            	Case "hide"
            		_SetCursor($rrpath & "null.cur", $OCR_NORMAL)
            	Case "unhide"
            		_SetCursor($rrpath & "normal.cur", $OCR_NORMAL)
            EndSwitch
               If Not @error Then
                  If Not @error Then
                  Else
                  EndIf
               Else
               EndIf
            RR commands:
            Code:
            "RUN;<path to script above>cursor.exe|hide"
            "RUN;<path to script above>cursor.exe|unhide"
              Learn something new every day! Was not even aware of the existance of the null cursor in the RR dir! Cool......
