RR Skin Editor
  • RR Skin Editor
    OK here is what i'm trying to do. I'm trying to either start AVS when i switch screens or have it constantly running. Does anyone know how to do this?
    ~The Build Process Begins~
    http://www.mp3car.com/vbulletin/newb...you-think.html
    ~The Build Process Ends~
    http://www.mp3car.com/vbulletin/show...completed.html
    Ok here is what i'm trying to do. I'm trying to either have avs constantly running or have it run on the next page when i click the button to switch to. I'm currently trying that with the lsx void skin. Has anyone ever done anything like that?
      RR Skin Editor
      I can't seem to find a RR skin editor that actually works i gut a bunch of jibberish when i open up the LSX Void Skin.
        Download the newest version of skin editor.
        http://www.mp3car.com/vbulletin/1189004-post62.html
          Thanks not sure why the first time i downloaded it didn't work. But all is well now thanks a lot
              the skin editor don't work
              error message " run time error 429"
              why??????
                Do you have the gdipluswrapper.dll(roadrunner folder) file reg? If so, was there anything else included with that error msg?
                Next in line: RRMedia v2.0
                DFX 5.1.1 Skin
                Appstore Link
                My RideRunner Plugins
                RRMedia
                RRExtended
                DFXVoice
                  Are you saying you want the visu to contnue to run on whatever screen you open as you navigate around?
                  Void does this by default.
                  At least, mine does..............
                  Leonardo Da Vinci
                    Yes thats exactly what i'm trying to do but mine doesn't do that. For instance if i move to alt_menu_cont.skin by pressing the arrow avs isn't embedded or isn't running but if i go back the main screen it does
                      You have to use a combination of commands to close it when you exit one screen and activate it again in the other screen; something like;
                      B........"VISU||LOAD;alt_menu_cont.skin||VISU"
                      OLD SYSTEM (DEAD)
                      Intel D945GCLF2 Dual Core ATOM
                      Lilliput 7" 629GL 2008 LED Backlight
                      BU-353 USB GPS Receiver / iGuidance / IGO8
                      M2-ATX Power Supply
                      RideRunner Front End / Various Skins
                      Windows XP SP3
                        hmmm so if i'm understanding this correctly the ordering of the commands is how its executed. For example "VISU||LOAD;alt_menu_cont.skin||VISU". Visualization start then load skin the start visualization. Is this correct? Cause what i tried was "BYVAR;VIZSTAT;LOAD;alt_menu_cont.skin||VIZON2<<al t_menu_cont.skin"
                        I did this to test if it visualization was on and if not turn it on but this doesn't work
                          I gave it a shot. AND IT WORKS!!!! there is a little flicker but thats ok. I guess i was trying to use a nuke to kill a ant lol.. Thanks treetop
                            This skin editor is so flaky i was running it on one comp and tried to move to another and now i get this error
                            anyone know what causes this error. I tried the older version and it worked fine
                              Operator error most likely did you register the .dll at it's new location?
                              OLD SYSTEM (DEAD)
                              M2-ATX Power Supply
                              Windows XP SP3
