No video within RR. "Over w/builtin & STOP w/MPC. Help appreciated!
  • No video within RR. "Over w/builtin & STOP w/MPC. Help appreciated!
    I've read every thread I could and searched relentlessly for the answer but to no avail so hopefully someone can point me in the right direction.
    First off, I read Guino's video faq, installed ffdshow, used the suggestion settings and video using mpc outside of RR works flawlessly. The problem is getting video to work within RR and it doesn't matter what skin I use.
    When I set it to use builtin, no matter what video I try to play, I always see "Over on the player tool bar (yes, with a leading double quote). When I specify to use media player classic, no matter what video I try to play, I always see STOP on the video player tool bar.
    Any suggestions?
    Thanks in advance to all who respond.
    "Imagination is more important than knowledge." -AE
    Let's see what that look like (screenshot).
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
      Have you told RR to support all the extensions your trying to play?
      Do these vids play in mpc when not using rr?
      P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
        He stated in the first message: "video using mpc outside of RR works flawlessly"....
        As mentioned, make sure you associate all the video file extensions with RR, and it doesnt hurt to associate all of them in windows with MCP as well.
        Also try deleting the video.ini in the RR root folder. Sometimes if this gets corupted, or a video that was last playing was deleted or moved, it will prevent RR from playing videos.
        My Fiero Build Thread
          Yes, all the extensions are defined and the vids play perfect in mpc outside of RoadRunner
            Here is a screen shot with MPC video specified in the configuration. You can see it displays STOP and there is nothing you can do and pressing buttons does nothing.
            and here is a screen shot with built in player specified in the configuration. You can see it displays "OVER
            No matter what video I try, it will not play inside RR and yes, it displays the same thing when using the default RR skin.
              Do you have WMP installed? Not MPC. Actual Windows Media Player.
              Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
                did you remove the video.ini?
                  Yes, I tried that. Videos play fine in WMP also.
                    No I didn't so I just removed it and it didn't make a difference. (thanks for the suggestion though)
                    Have you ever noticed that when you start MPC, you see a quick, splash like video frame that displays 321 in large numbers? Well, when I first click video in RR and it defaults to try to play the last video, I see that 321 appear and disappear really fast but nothing after that.
                      Yes, i think i saw a thread where it concluded that the built-in player does feed off windows media player (i could be wrong tho') EDIT: came in late on this one.
                      Also in RRConfig, make sure the path to media player classic is correct and don't have a back-slash at the end.
                      OLD SYSTEM (DEAD)
                      M2-ATX Power Supply
                      Windows XP SP3
                        Everything looks fine. Like I said previously, I can see the 321 appear and disappear real fast.
                        Appreciate all the suggestions...this has been driving me nuts for over 2 days now...
                          post your rr.ini
                            post your rr.ini
                            OK, here it is:
                            [Player Setup]
                            player=Winamp
                            inipath=C:\Program Files\Road Runner\
                            winamppath=C:\Program Files\Winamp\
                            hidewinamp=true
                            exitmute=true
                            [General]
                            voice=false
                            disableinternat=false
                            showicons=false
                            showextensions=false
                            hidemouse=false
                            hidetaskbar=true
                            hidedesktop=false
                            hidedots=false
                            gpstime=false
                            gpsusadate=true
                            exitmode=0
                            dateformat=Short Date
                            timeformat=Short Time
                            locale=0
                            screentype=4:3
                            debugmode=true
                            enableclipping=true
                            nozoom=false
                            usegestures=false
                            leavemousealone=false
                            closeapps=false
                            fastmode=-1
                            usedualmon=false
                            soundcard=0
                            screenlimit=10
                            mastervolmap=0
                            hibernateaware=false
                            forcehibernate=false
                            hibernatereload=false
                            usbsound=false
                            browsertype=0
                            usevoicecontrol=false
                            usecar2pc=false
                            fadeinvolume=true
                            picspath=To set path, Click --->
                            [Skins]
                            skinpath=C:\Program Files\Road Runner\Skins\BMV2\
                            nightskin=C:\Program Files\Road Runner\Skins\BMV2\
                            transition=-1
                            background=To set path, Click --->
                            TransitionTime=0.2
                            [Gamma]
                            gammamode=3
                            gpsgammamodeoffset=0
                            gammaday=0:0:0
                            gammanight=-50:-50:-50
                            gammadaytime=1:00
                            gammanighttime=1:00
                            autogammamode=1
                            autoskinmode=1
                            [Preload Screens]
                            [Music]
                            musicpath=D:\MP3\
                            playlistpath=D:\MP3-Playlist\
                            useid3=0
                            singleclickaudio=false
                            noformat=false
                            listnumbers=true
                            listfollowssong=true
                            id3listformat=%title%
                            id3browseformat=%title%
                            titlesafter=-
                            albumart=*.txt
                            fadeimages=false
                            visuname=MilkDrop
                            scrollmode=1
                            circularlist=false
                            groupnumbers=false
                            resumemusic=0
                            audiorepeat=false
                            audioshuffle=false
                            transparentvisu=false
                            opacityvisu=40
                            [Radio]
                            radiomode=0
                            allowallfreqs=false
                            radioline=0
                            userbds=false
                            [XM]
                            xmport=0
                            xmline=0
                            xmlineinplugin=false
                            xmtype=0
                            singleclickxm=false
                            xmformat=%station% %artist%
                            [SIRIUS]
                            srport=0
                            srline=0
                            srlineinplugin=false
                            singleclicksr=false
                            srformat=%station% %artist%
                            [Video]
                            videopath=D:\Videos\
                            mpcpath=C:\Program Files\Road Runner\mplayerc.exe
                            videoautohide=false
                            builtinvideo=false
                            videofiles=.asf,.avi,.m2v,.mpeg,.mpg,.nsv,.vob,.wm v
                            videoshuffle=false
                            [TV]
                            tvline=0
                            [GPS]
                            gpsmode=2
                            mapmonkeypath=Click here to set path
                            gpspath=C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe
                            gpsname=iGuidance
                            overspeed=55
                            gpsport=0
                            mappointmap=1
                            mapcountry=United States
                            mapcity=
                            mapautozoom=true
                            isunits=true
                            usegpsserv=false
                            gasfinderautorefresh=false
                            [IG Native]
                            ignative=true
                            igautosw=false
                            gpsonvoice=true
                            pauseonvoice=false
                            lastscreenswitchtime=5
                            [Speed Att Vol]
                            speedatt=false
                            [Phidget]
                            phidget1=0
                            phidget2=0
                            phidget3=0
                            phidget4=0
                            phidget5=0
                            phidget6=0
                            phidget7=0
                            phidget8=0
                            [4 Temps]
                            tcomport=0
                            tempscale=c
                            temp1=c
                            temp2=c
                            temp3=c
                            temp4=c
                            [Volt Meter]
                            vcomport=
                            [Phone]
                            phoconodesign=false
                            motophone=false
                            phonelistspath=Click here to set path
                            contactspicturespath=Click here to set path
                            ringtone=Click here to set path
                            smstone=Click here to set path
                            maxcalllistentries=100
                            phoconoincallevent=false
                            connecthsp=true
                            standardphonebook=0
                            phonebooksencoding=windows-1252
                            [Weather]
                            cityweather=
                            weatherunits=USA
                            weatherdegress=
                            localdatacaptureinterval=0
                            [Extra's]
                              post your rr.ini
                              And here's the debug file using MPC....
                              5/22/2008 10:32:51 AM: Start -- Version: 5/8/2008
                              5/22/2008 10:32:51 AM: Master Vol: Volume Control/4
                              5/22/2008 10:32:51 AM: GetLineControl Failed: 401
                              5/22/2008 10:32:51 AM: No Treble Support
                              5/22/2008 10:32:51 AM: No Bass Support
                              5/22/2008 10:32:51 AM: No Master ON/OFF
                              5/22/2008 10:32:51 AM: Source: Wave=&H1008/1
                              5/22/2008 10:32:51 AM: Source: SW Synth=&H1004/2
                              5/22/2008 10:32:51 AM: Source: Microphone=&H1003/3
                              5/22/2008 10:32:51 AM: Source: CD Player=&H1005/4
                              5/22/2008 10:32:51 AM: Source: Aux/Phone=&H100A/5
                              5/22/2008 10:32:51 AM: Source: Line In=&H1002/6
                              5/22/2008 10:32:52 AM: Sim.WMSGs: 1
                              5/22/2008 10:32:52 AM: Sim.WMSGs: 2
                              5/22/2008 10:32:52 AM: Enter Exec: False, menu.skin, , False
                              5/22/2008 10:32:52 AM: Que Exec: True, menu.skin, "ONSKINSTART", False
                              5/22/2008 10:32:52 AM: Executing: ONSKINSTART
                              5/22/2008 10:32:52 AM: Leave Exec: False, menu.skin, ONSKINSTART, False
                              5/22/2008 10:32:52 AM: Que Exec: True, menu.skin, "ONSONGSTART", False
                              5/22/2008 10:32:52 AM: Executing: ONSONGSTART
                              5/22/2008 10:32:52 AM: Leave Exec: False, menu.skin, ONSONGSTART, False
                              5/22/2008 10:32:55 AM: Enter Exec: False, menu.skin, "VIDEO", False
                              5/22/2008 10:32:55 AM: Que Exec: True, menu.skin, "VIDEO", False
                              5/22/2008 10:32:55 AM: Executing: VIDEO
                              5/22/2008 10:32:56 AM: Shell: "C:\Program Files\Road Runner\mplayerc.exe"
                              5/22/2008 10:32:56 AM: Leave Exec: False, menu.skin, load;video_player.skin, False
                              5/22/2008 10:32:56 AM: Enter Exec: False, video_player.skin, , False
                              5/22/2008 10:32:56 AM: Que Exec: True, video_player.skin, "ONSONGSTART", False
                              5/22/2008 10:32:56 AM: Executing: ONSONGSTART
                              5/22/2008 10:32:56 AM: Leave Exec: False, video_player.skin, ONSONGSTART, False
                              5/22/2008 10:33:00 AM: Enter Exec: False, video_player.skin, "EXIT", False
                              5/22/2008 10:33:00 AM: Que Exec: True, video_player.skin, "EXIT", False
                              5/22/2008 10:33:00 AM: Executing: EXIT
                              5/22/2008 10:33:00 AM: Leave Exec: False, video_player.skin, load;menu.skin, False
                              5/22/2008 10:33:00 AM: Enter Exec: False, menu.skin, , False
                              5/22/2008 10:33:00 AM: Que Exec: True, menu.skin, "ONSONGSTART", False
                              5/22/2008 10:33:00 AM: Executing: ONSONGSTART
                              5/22/2008 10:33:00 AM: Leave Exec: False, menu.skin, ONSONGSTART, False
                              5/22/2008 10:33:02 AM: Enter Exec: False, menu.skin, "EXIT", False
                              5/22/2008 10:33:02 AM: Que Exec: True, menu.skin, "EXIT", False
                              5/22/2008 10:33:02 AM: Executing: EXIT
                              5/22/2008 10:33:02 AM: Shutdown
