how to make flash buttons that work with RR
  • how to make flash buttons that work with RR
    well the title says it all...
    does anyone have a step by step dummies guide on how to make flash buttons that work with RR. or know of any links to some basic info
    ive tried searches but there are to many results.
    im trying to make buttons like this for menus etc
    Button1.swf
    mainly im not sure how to put the commands in flash, so they work with RR.
    Code:
    on(release){
    fscommand("PLAY")
    this would do as a regular "PLAY" button does. one thing that you can do to make changes, is to use an ExecTBL.ini in your skin as well,
    so if you have in your ExecTBL.ini a defined command called
    Code:
    "BUTTON1","AUDIO"
    and in your flash object you use
    Code:
    on(release){
    fscommand("BUTTON1")
    when you use the button audio will be launched, if you change your mind and want to use "BUTTON1" for video you don't have to adjust the flash object, just the ExecTBL can be changed.
    Code:
    "BUTTON1","VIDEO"
    BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
    RRTube ==> [View/Download Youtube Videos]
    WifiMan ==> [Wifi Manager]
    RRec ==> [Audio Capture]
    If You Want To Be Given Everything, Give Everything Up ...
    Bird York -- In The Deep --
