RR error, stopped working
  • RR error, stopped working
    I got three errors when trying to load RR. I just had a crash yesterday and had to reinstall everything. Here are the errors:
    Run-time error '440':
    Automation error
    Run-time error'-2147200966
    Automation error
    Run-time error'-2147221001 (800401f7)':
    Application-defined or object-defined error
    Any help would be greatly appreciated.
    I told my psychiatrist that everyone hates me. He said I was being ridiculous - everyone hasn't met me yet .
    Did re-installing fix it?
    You may have hard drive problems. During the summer in the heat or if you drive on some rough roads it is pretty tough on the hard drives. This happened to me a few times in the last 3-4 years. My hard drive was junk it got to the point where windows could even complete an install. Replaced it with a new one and whamo it worked. Most hard drive manufacturers have pretty good warranties and are pretty willing to replace it for free if you call and let them know. Seagate replaced my 250gb with a 300gb completely free the only thing they asked is that I send them the bad one. The hard drive had a 5 year warranty by the way.
    Done did
    New Age Garmin - Skin for RR
      Reinstall worked. I had to do it twice to get it to work. The second time, I had to delete everything from my rr file except the install program. But it works again. Thanks everyone.
        That is an early warning of harddrive death... Might want to budget for a new one, it wont work for long.
        1.9in x 2.9in -- 47mm x 73mm
