Question On Sliders
  • Question On Sliders
    I'm trying to get sliders to work in the MIXER skin. I have the skin drawn etc and have drawn "bar graph" slider images for slider0.jpg -> slider20.jpg
    however when I test the skin the bar graph display is off by about 5% ... when the volume is set to 50% the bargraph is at the 45% level ... when the volume is at 100% the bat graph is at the second last level (95%) it never goes to the max level (slider20.jpg) ...
    it looks like the scale onlt goes from 0 - 19 ...so the bar grapgs should have 19 segments and not 20 segments as seems to be the case on other slider that I looked at for inspiration ... that way when the slider reaches slider19.jpg it is at max level ...
    has anyone else come across this issue when implementing sliders ?
    thanks ...
    valheru.
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
    Yup...which is why i use pointers for stuff like that.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
      Did you solve this as I've got same problem on Reborn skin
        I just tried RR 12/12 and that slider issue is fixed in 12/18 beta.
          nice .. i'll give it a whirl and check.
