RR install help needed...
  • RR install help needed...
    ...so I'd like to install RR, but can't use the installer. I hope I don't have to spell out why I can't use the installer.
    I've downloaded the latest binary and registered all the DLL's. Upon startup, I get an error message saying that Road Runner is unable to locate Time Zone information in the registry under key "Software\Microsoft\Windows NT\CurrentVersion\Time Zones"
    Any insights on how to get RR up and running?
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    I checked the registry and tons of time zone info is in there.
    Anyone have any idea what RR is unable to locate in there?
    Hello?
      Do you have any anti virus software running or anything?
      Everything should run fine from this link..
      http://www.carpcnet.com/component/op...,52/Itemid,26/
        The anti-virus is not the problem.
          Can't or won't? Is the question....
          Next in line: RRMedia v2.0
          DFX 5.1.1 Skin
          Appstore Link
          My RideRunner Plugins
          RRMedia
          RRExtended
          DFXVoice
            Sal, how can you, of all people, not get RR to fire? what version are you using?
              Can't. It's a permissions thing.
                I know, huh?
                I'm using the 12-13-07 version.
                  MicroXP issue is my best guess.
                    No. No problems w/ MicroXP.
                    RR isn't being installed on a MicroXP'ed machine.
                    It's being installed on a new machine where I don't have *ahem* "sufficient previlages."
                    So, a work around is needed.
                      Add your user name under the "administrators" group.
                      start > run > mmc > user snap in
                        It's probably at work or something where he doesn't have administrative privileges. Or the password to log in as an admin.
                          *ding*
                          I know...bad Sal...bad Sal...
                            I'm betting your username doesn't have sufficient access to the registry key.
                            What happens if you try to alter the value of it yourself? Does it give "access denied"?
                              It says that it's being access by another program or resource.
