RR does not accept app comands?
  • RR does not accept app comands?
    I'm setting up a Tablet to run RR and one of the things I can do is configure case buttons to send various app commands. One of these is the play/pause toggle command. However, this doesn't work with RR. Is there an alternative way I can get the case button to pause/resume playback in RR?
    Yes, you should be able to do that...
    First look in your rr folder for a file called keycode.exe, then write down the numbers that it gives you for each of the buttons pushed. Next go to your roadrunner folder and open up the keytbl.ini file and add the numbers, one to each line with the command that your want to execute/associate with that button.
    Example, for the play button on my keyboard the line would look like this, the 179 is the number that the keycode.exe gave me,
    179,"Play"
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
