need help in install
  • need help in install
    Hi,
    Since 2 weeks I am trying to install roadrunner, I download my installers from many sites but still I am facing same problem.
    When I click on the RoadRunner installer (RR_Install.exe) its install the software without any problem, its install the winap with the RoadRunner also.
    Once the install finished it runs the RoadRunner Config ( RR Config window ), I configured my GPS, Winap directory ,,, etc, then I save and Exit from the RR config window.
    When I lunch RoadRunner, new window appears looking for RoadRunner.msi file as showing in bellow image.
    I put the RoadRunner.msi file directory, it continues the startup, until bellow eroor window appears.
    So when I press ok the software will terminated.
    So any body can help me please
    Waiting for your kindly replay
    Maybe this: http://www.mp3car.com/vbulletin/road...every-day.html
    Also make sure the folder is named Road<space>Runner
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
      i tried,, but its not working,,
      i need help please
        What did you do? be specific.
        If it's a AV problem, don't use the installer you downloaded previously, the AV probably desabled the .exe.
        Turn off the AV; download a fresh installer and start over. Have the AV off during the whole process and see..
        OLD SYSTEM (DEAD)
        M2-ATX Power Supply
        Windows XP SP3
