how can you save a playlist?
  • how can you save a playlist?
    that without using blue's monster.. I just wanna save it as mu3 file in rr. Is it already there?
    pertty sure theres a command 'SAVELIST' ?
      "savelist"
      OLD SYSTEM (DEAD)
      Intel D945GCLF2 Dual Core ATOM
      Lilliput 7" 629GL 2008 LED Backlight
      BU-353 USB GPS Receiver / iGuidance / IGO8
      M2-ATX Power Supply
      RideRunner Front End / Various Skins
      Windows XP SP3
        i have an autoitscript that grabs all playlist's in your $PLAYLISTPATH$, displays them in a custom list so that you can save the current RR playlist to an existing playlist OR create a new playlist. Should you wish to create a new playlist u click that line in the custom list and osk appears allowing you to name ur new playlist. Then its saved right into playlistpath. Now there might be 15 ways to do this all within RR but hey mine works and looks cool in use
        Live mp3Car Facebook Chat
          sonic, "mine works " which one? Upcoming one or previous one? Would you share ur wisdom please... Let me try ur previous skin..
            Your skin must have a DL "S" and SD,...,"$playlistpath$","*.m3u" defined for the code below to work.
            Save New Playlist:
            BXX,...,"OSKTOCMD;playlistname;SAVENEWLIST"
            Replace Existing Highlighted Playlist:
            BXX,...,"SETVARBYCODE;playlistname;LISTTEXT||SAVEL IST;$playlistpath$$playlistname$"
            ExecTBL.ini:
            "SAVENEWLIST","SAVELIST;$playlistpath$$playlistnam e$"
            GL.
            Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
              sal.. that's way over my head... do you have working skin or screen you can share?
                I do. MMIv2.
                However, the coding for that skin is much more complex that I posted.
                The code above is simple. Create a skin with the following properties:
                Two buttons.
                1 DL list
                SD definition.
                Copy the button codes (the text b/w the " ") into each of your buttons.
                Copy the text for ExecTBL.ini.
                Start RR.
                  Save New Playlist:
                  ExecTBL.ini:
                  GL.
                  see i knew there was a way to do it all in RR lol
                    Playlist Managment
                    You can actually do all this with RR code and a few other handy things for managing playlists fairly simply.
                    Create a skin with a standard list on it. Call the skin with the following button code, (to tell it to show your playlist path in that list when the skin loads)
                    Code:
                    "Load;AudioPlayListLoad.skin||SETPATH;$PLAYLISTPATH$"
                    To create a new playlist
                    button code:
                    Code:
                    "OSKTOCMD;PLFileName;SaveNewList"
                    Then put this in the exectbl:
                    Code:
                    "SaveNewList","SAVELIST;$PLAYLISTPATH$.\$PLFileName$||MENU;PlayListCreated.skin||WAIT;2||EXIT||SETPATH;$PLAYLISTPATH$"
                    To Relpace a Playlist selected in the list:
                    Button Code:
                    Code:
                    "SETVARBYCODE;LISTTEXT;LISTTEXT||SAVELIST;$PLAYLISTPATH$$LISTTEXT$"
                    To Delete the selected Playlist:
                    Button Code:
                    Code:
                    "DELETEFILE"
                    To Rename the selected Playlist:
                    Button Code:
                    Code:
                    "RENAMEFILE"
                    My Fiero Build Thread
                      nice... I'll try and see how it goes.. will come back with more question on this..
                      Thanks alot guys..
