How to Config RoadRunner?
  • How to Config RoadRunner?
    Hi guys sorry if this has already been posted but I've been searching for days and haven't found anything...
    I am currently running iGuidance with road runner and using Xport.
    using Xport I've shared com port 3 to 4 and 5..
    my iGuidance reads com 4 fine but how can I get road runner to read com 5? is there a file or something that I have to edit?
    I've been looking around and read post after post but no one says how to get roadrunner to read a com port.
    please help.
    and thank you.
    Those dang noobers.
    Have you looked around in the RR Config program? I'm pretty sure the setting is in there...
    Tidder
    Try RevFE
      actually I did.. and there is nothing about changing the com port.
      sorry I know it's a nob question.
        Well if you can't find it in rr config, you can change it in rr.ini file. If it's a fresh install, it'll show up as gpsport=0.
        EDIT: Tho I'm sure under the GPS section in the config program, there's a gps port setting there. I'm sure of it. Unless they've changed the config proggy recently.
        Tidder
        Try RevFE
          path to rr.ini on a typical install is C:\Program Files\Road Runner\rr.ini
          Sorry, shoulda mentioned earlier.
          Tidder
          Try RevFE
            please help.
            and thank you.
            First, start Xport. Now set the input com port to the port of your GPS receiver.
            Next, In the lower part of Xport, Check "Enable Service" then, under OUTPUT set up the virtual com ports you would like to use ( 4 and 5 ).
            Now Put the 4 in Road Runner's GPS config, and 5 in your GPS program. So now your Receivers com port is split into two virtual ports. Hope this helps
            If you cant DODGE em, RAM em.
              Thank you so much guys! and once again sorry for the nob question, i am sure you guys might be tired off that question!
                Actually, that one was a first for me. Usually it's more along the lines of skins and screen config and junk. I'm dying to find out why you don't have GPS options in your config program though...
                Tidder
                Try RevFE
                  I just uninstalled and reinstalled roadrunner and it pop up under the GPS Settings...
                  before it was just a blank grey window.
                  thanks alot for your help... you guys are great got it working now.
                    How weird. I have issues with the rr config proggy from time to time, but nothing like that. Usually my issue is it just won't run.
                    Tidder
                    Try RevFE
                      I get that to, been using it for a few month already. but it's one off the best programs I've used so far for CarPc.. it as alot off support, and alot off new stuff all the time,
                      so can't complain.
                        Gee....Thanks...
                        My second most important contribution to the RR community
                        Next in line: RRMedia v2.0
                        DFX 5.1.1 Skin
                        Appstore Link
                        My RideRunner Plugins
                        RRMedia
                        RRExtended
                        DFXVoice
                          what is xport? i just set up BU-353 with iGuidance. is that xport something i should be using?
                            Xport is another program that splits your gps signal from your device,
                            basically it adds a virtual com port, as many as you need,
                            so origanal com port is say 5
                            run xport and add 2 more com prts 2 and 3 say.
                            now in rrconfig set gps com port to 3
                            and in iguidence set com port to 2
                            now rr and ig are both getting gps signal.
                            Riderunner / Genesis
                            Wifiman_NET:Version 1.0.0
                              ohh ok. so my gps won't work properly in rr unless I do this? so its pretty much required then?
