*** NEW MJS BUILD OF RR (08/07/08) - NEW XM, SIRIUS, HD (and minor other thing)
This topic is closed.
  • *** NEW MJS BUILD OF RR (08/07/08) - NEW XM, SIRIUS, HD (and minor other thing)
    OK, this looks to be the final version, there might be 1 thing ill change, but its a technical coding issue.
    Since really no one has reported any issues, and 1 its working great, or 2 no one is using it. There is no point for me to sit on it anymore, might as well release.
    I will get this to guino for a merge, but once i do, i lose the tecnically abiliby to look at the code or work on it further. Hopefully the merge goes smooth and complete.
    Take note, read the installation text file. To keep it simple run "MJSG-RR-RunMe1st.cmd" which will register all the .net assemblies, since they are all coded by me, i put them in thier own directory "MJS Gadgets". if you have HDRadio or XMRadio directories in the RoadRunner Root, unreg them, and delete, they are all now part of MJS Gadagets directory.
    the MJSUAS is coded as a PLUG IN NOW, and ill post that in another thread
    "Required Skin.zip" contains a popup which should be placed in you're current skin directory, of course if you feel like re doing the images in the skin, post them for others...
    technically you only see this popup, if there is a problem with XM, Sirius, or HD Radio. AND when Sirius Channel Map changes.
    hopefully im remembering everything... if not ask away
    REMEMBER this is built off 11/07 CODE, so it has less features and more bugs then the 5/08 code does, but this ISNT my fault, and i had NO control over it. the other option was I dont get involved, and u deal with poor performing XM Radio/Sirius/HD Radio. I know I for one wouldnt like any delay when switching from say radio to xm, to mp3s...
    Mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Thanks Mitch. What is the changes made in this version over the 7/18 build?
      i whish i knew, deadly, from 7/18 a ton!
      Sirius got rewritten after 7/18
      the "INC" skin command got up to date with say 5/08 made alot of skins work better
      from 7/31 to 8/7 was mostly cleanup and finalize
      mitch
      -Thanks
      Mitch
      www.rush2112.net
      Wind, Carry me home
        good work as always mitch. Thanks
        BTW, i showed of your UAS at a car meet on saturday.. Be prepared to take some orders soon! lol
        Live mp3Car Facebook Chat
          ya, good work! i was running 8/x ver.. not sure day anymore.. heh but it was working great... n ever had issues...
            Awesome, Thanks Mitch for all the work you have put into making RR even better.
            This new version will support everything the official beta does, only more intuitive and faster.
            Let me know if you need any more help testing future builds or more artwork done to help the process along.
            -Joe
              its this thread!!!!
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                move converstaion here
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  Yes, an enclosure whenever you get time to ship it. No hurry. It is installed and working GREAT!
                  The Car 2005 Scion xB
                  The Truck 2004 GMC Canyon
                    hey mitch.. is it possible to add a flag in rr.ini to override your messageboxes? Right now i have to switch to 11/7 Roadrunner to skin for xm/sirius/radio on a computer without those devices installed.
                      Should be able to set radioline=0 & xmline=0
                        that doesnt make the message boxes go away when u attempt to change to xm etc
                          oops, I meant xmport=0 & hdradioport=0. But, you are correct, it still says that the port is set to 0..... sorry for the misinformation....
                            sonic, i have no idea what ur talking about
                            -Thanks
                            Mitch
                            www.rush2112.net
                            Wind, Carry me home
                              currently there's NO way to enter radio_player.skin or xm.skin or sirius.skin if the hardware is not connected. This means that anyone who is creating an RR skin cannot test any of those skins if radio, xm , and sirius devices are not installed So if you can add an option to rr.ini... Something like TESTMODE=TRUE, it would override your pop up skins and allow access to those skins for testing. As i said before the only way i can test sonique elite right now is go to and older rr.exe or skin, take it to the car and test, then come back to fix. Not very efficient
