RR locks up when going to the Audio screen, but audio plays fine thru winamp alone
  • RR locks up when going to the Audio screen, but audio plays fine thru winamp alone
    So I have been bench and in-car testing my setup and finally today put it together. It is working just fine except for some reason, when I click the "audio" button in RR (LiquidSmoke Skin), it locks up. The startup music and everything else is working fine. I also tried loading winamp, loading up some tracks, then playing them and it works fine. When I do this, then go back into RR and hit the play button, music plays just fine, but again if I try to go to the "Audio" menu to edit playlists or whatever it locks up. It switches/plays video fine, goes to the navi screen and back just fine.
    Any ideas?
    Oh and also - I just noticed that on the home screen it doesnt display song name/title/etc. any more.. it's just blank (i.e. song info not scrolling)... it does show up on the other screens though which is weird (i.e. Nav)
    Thanks!
    You need to define your media path on the options screen in void or it will lock up.
    It plays when you start winamp first because winamp already knows the path and void doesn't have to define it.
    All this info can be found in the void thread...........
    Leonardo Da Vinci
      The path is fine (i assume b/c it was working just fine before, and I didn't change any settings). I can check the path in RRconfig, but when I try to go to the options menu within LSX, it locks up as well.
      It doesn't lock up switching to audio when I use the default skin.
        try registering...
        dx7vb.dll
        GDIPlusWrapper.dll
        mitch
        -Thanks
        Mitch
        www.rush2112.net
        Sun, Come shine my way
        Wind, Carry me home
        The piece of me that died
        Will return To live again
          mitchjs,
          I've documented an issue in the RR Bug Forum ([URL="http://www.mp3car.com/vbulletin/rr-bug-tracker/124244-resume-command-throws-rr-100-a.html"] and was wondering if your comments in your last post would apply.
          I would appreciate if you would look at that bug post.
          I'm at my wits end trying to figure out what is happening to cause RR to go to 90-100% and the problem is delaying my progress towards an install of my system in one of my cars.
          Any thoughts or comments would be appreciated/
          Oh BTW, could you refresh my memory (and probably others) on how to register a dll.
          Regards,
          Jim O'Brien
            Regards,
            Jim O'Brien
            http://www.tech-faq.com/register-dll.shtml
            Leonardo Da Vinci
