Change Skin doesn't seem to work
  • Change Skin doesn't seem to work
    I seem to be having an issue changing skins. I can do it just fine from RRConfig by selecting the day and night skin. However, if I attempt to change it from with Road Runner itself, it loads it but is frozen for about 2 seconds. Then it just reverts back to the previous skin. I've even tried choosing the same skin that's being used by RR already, and it does the same thing as described above.
    I hope I've explained it right. Is this a bug or am I missing something in the config somewhere?
    I am currently using version 1.0.1.0 with WinAmp 2.95. I have installed skins Crystalblue and Crystalsilver.
    Carputer progress meter: [-----|]
    Carputer gadget meter: [--|---]
    Have you set "Auto skin change" in your RoadRunner config ?
    The general.ini in the skin folder holds a Daytime= and a Nighttime= value. RR looks up those values. When "Auto skin change" is activated, RR automatically switches to the according skin.
    I guess that's your problem. You manually switch to the night skin, rr reads the mentioned values of the night skin and automatically switches back to the day skin.
    Turning off "Auto skin change" or deleting those settings in the general.ini of the skins should help.
      Gamma --> Auto skin change --> Auto Skin change Disabled FTW
      Thanks for the help. I'm an RR nooby and I'm still trying to learn how it all works. It would be nice if Gamma was labled Gamma/Auto Skin. I might have spotted it earlier.
        this helps me a lot, thanks!
