Help with gpsspd RR label
  • Help with gpsspd RR label
    How can I get GPS speed from a label with out the mi/h in the label
    For instence I want 65 instead of 65 mi/h
    Or is there a different way to get this info.
    Trying to create a speedlimit script.
    New Age Garmin - Skin for RR
    You can use Blue's plugin HERE.
    Then you just use:
    Code:
    "StrRepl;GPSSPD;mi/h;;MySpeed"
    BUT, if you are creating a script, I you can easily do it right on the script when you grab the speed from RR:
    Code:
    $MySpeed = $RR.GetInfo("GPSSPD")
    $MySpeed = StringReplace($MySpeed , "mi/h", "")
    $MySpeed = StringReplace($MySpeed , "km/h", "")
    '  Or, If you are using VB then:
    MySpeed = Replace (MySpeed , "mi/h", "")
    MySpeed = Replace (MySpeed , "km/h", "")
    My Fiero Build Thread
      The latter is the better way, unless your using my plugin for other string/var related things too..
      Next in line: RRMedia v2.0
      DFX 5.1.1 Skin
      Appstore Link
      My RideRunner Plugins
      RRMedia
      RRExtended
      DFXVoice
        Thanks that worked great...
