how to launch a program without its own skin?
  • how to launch a program without its own skin?
    tried to embed kmplayer... It looked like it got embeded alright, but it's flashing, on and off, on and off for some reason.. I think it doesn't like it.. So, this is what i am trying to do. Is there a way to launch a program with no screen?
    Thanks..
    you can but you won't be able to get back to rr ,unless you hit esc on your key board , have you tryed to clip and area instead, ie have a skin file but instead of a "A" line a"c" that way anything under rr will show through , this is how we are doing Coverjuke at the moment.
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
      That's fine carputer1. i can leave with that... So, how can i launch an app?
        "APPNAME","RUNQ;$rrpath$PATH TO APPt\APP.exe"
        this in your exectbl.ini appname anything you like and set the path to the app exe should do it. if you are clever enough look at johns ig full scr line for ig ,i think you can do the same.
        it puts a icon top right of the scr which will take you back to rr, may have to change the code abit but its worth ago.
          got you.. I'll give a shot at it and see how it works
          Thanks..
            I'm Struggling with this too. I want to run a program when I exit a skin something like this, but I can't get it going
            ExecTbl.ini
            "OZISAVE","RUNW;$rrpath$OziSave.exe"
            On the Skin exit button, I put this:
            B02,656,000,046,053,"OZISAVE||SENDKEY;%x||CLOSE"," Close"
            But I can't get this to work, so I tried redefining OZISAVE to :
            "OZISAVE","RUNW;calc.exe"
            And I still have not had any luck. Any pointers would be appreciated.
            RodW
            2007 Toyota Hilux with a CarPC..
            Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
            OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
              it works for me.. it will launch a program you specified.. how about calling it directly?
              B02,656,000,046,053,"RUNW;$rrpath$OziSave.exe||SEN DKEY;%x||CLOSE"," Close"
              Just to make sure, you do have ozisave.exe in rr folder, yeah?
                Yep, checked the file was there and tried another folder just in case it does not like spaces in a path (eg. "Road Runner").
                I had started trying to call this directly until I saw how to use an ExecTBL.ini entry which seemed cleaner. Tried again with no luck.
                So If I define OZISAVE to be this in ExecTBL.ini:
                "OZISAVE","RUNW;C:\WINDOWS\system32\calc.exe"
                shouldn't calc be displayed? I can't get ths to work either
                RodW
                  "OZISAVE","RUNW;$rrpath$calc.exe" if cal.exe is in rr root , example,
                    Isn't that what I have done except that I used the full path to the default location for calc.exe ?
                    It still does not work
                    RodW
                      that's odd... It doesn't do anything?? Turn the debug on and see what's going on or post it, so more people can take look at it...
                        Ok, so now I know it's not me, so how do you turn debug on? I think I'll play until I can get calc.exe running
                        RodW
                          run rrconfig >> page 2 >> debug enabled..
                            "RUNW;$rrpath$OziSave.exe||SENDKEY;%x||CLOSE,Close "
                            YOU HAD too many quotes. You only need a quote and the beginning and the end of the command string.
                            New Age Garmin - Skin for RR
                              To launch a program in it's own skin use this command
                              "LOAD;EXTERNAL_GPS.SKIN;Destinator GPS;Destinator3.EXE;Destinator"
                              RR SKIN NAME Window Name PATH/Executable What RR Says when Executed
