09/09/08 OFFICIAL MJS Road Runner Release
This topic is closed.
  • 09/09/08 OFFICIAL MJS Road Runner Release
    This is It!
    Guino, did a wiz of a job merging all my changes/updates to the NEWEST BASE RR CODE (5/27/08). Also There are a few other things fixed.
    .NET Framework 2.0 is required!
    the XMComm.dll is Required to be registered, EVEN if you dont have XM Radio
    --- Changes that are new to this build ---
    * Fixed the dreaded Indicators in plugins BUG!
    (a small change of PLUGINS must be done, i have a new example plug in)
    (its so small, its basicly changing "false" to "")
    * Fixed Silders in plugins!
    --- Changes that are from my MJS Builds ----
    * Complete rewrite of XM Radio, Sirius Radio
    * Partial rewrite of HD Radio
    * Changes in last source resuming
    I need to update the NOTES, but one thing after installing...
    if you got in the "Road Runner" directory a directory called "HD Radio" and/or "XMRadio" you can delete them!!! XM/Sir/HD controll .dlls are now all in "MJS Gadgets" directory.
    *** I will edit this post further ***
    *** Guino will add some notes too ***
    *** Its Late... need sleep! ***
    The file here is a MINI installer, it will backup any existing "Roadrunner.exe", install the new "Roadrunner.exe" + the "MJS Gadgets" directory, and automaticly register the required .DLLS
    also the "Required skins.zip" file, contains a popup box, unzip and drop the files into your current skin(s). its used to provide error/infomation about XM Radio/Sirius Radio/HD Radio
    I will post the Sample Extension plugin code, and my NEW UAS plugin!
    So much to do, so tierd... will be back in the morning, but i wanted to get this out!
    Also Bluezx3 is working on a updated RRConfig, with all the new stuff! (THANK YOU)
    there is a bunch of people that really need to be thanked:
    Sonicxtacy02, blk02si, GizmoQ,
    barnyard, JohnWPB, Dave321
    And of course GUINO!
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Yess!!! Been waiting for this for a long time! Thanks to everyone involved for all the hard work and effort on RR!
    Going to try this out right now!
    2004 Mazda3 Carputer Worklog - Update 5/17/11: Carputer 2.0 Hardware Selection
      Good Deal. Thanks for all the hard work guys.
      CAR: 2007 G35 Sport Coupe 5AT
      HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
        Thanks for all your hard working.. a tiny issue with mp3art.. It used to display folder.jpg if no art is presented in mp3 file. Now, it flashes folder.jpg and display empthy... Is just me or do you experience this as well?
          Try this updated Mp3Art.dll file that has been fixed to work with the new RR release. Have not tried this to see if it works yet!
          Next in line: RRMedia v2.0
          DFX 5.1.1 Skin
          Appstore Link
          My RideRunner Plugins
          RRMedia
          RRExtended
          DFXVoice
            sorry, but no installation possible.
            get a break if the installer tries to reg the radios. it shows a new road runner.exe in the path without running.
            i use no XM, SIRIUS or HD radio.
              Thanks for the update.
              P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
                Same here.
                  Thanks for the new release.. Could you please post the Roadrunner.exe only?
                    Originally posted by Griff1 View Post
                    Same here.
                    This is NOT possible with this release!!
                    The XM,Sirrus,HD files are now a part of the requirements for this and most likly all future RR releases.
                    After the installer runs, go into the MJS Gadgets folder and then go into each of the three folders and run each of the runme1st.cmd files then startup RR.
                    DFX 5.1.1 Skin
                    Appstore Link
                    RRMedia
                    RRExtended
                    DFXVoice
                      GF-Ler, Griff1, sounds like you're MISSING .net Framework 2.0
                      its required, and at the very least XMComm.dll MUST be registered
                      MJSG-RR-RunMe1st.cmd can be used to register
                      See I knew id forget to mention everything, I Edited top post
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        thanks, i was the reason.
                          OK, i added .net 2.0 Framework check to the installer
                          this is also my 1st time using INNO setup, so bear with me guys!
                          and I cant think of everything, so much work involved here!
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
                            I m p o r t a n t
                            Unless the instructions are followed above, clearly spelled out my Mitch, there are going to be LOTS of "It does not work!" posts.
                            If you wish to use the new RoadRunner build:
                            1. You MUST install .net 2.0
                            2. You MUST use the installer, as the required DLL's are installed with it. If you were to try to run just the new RoadRunner.exe without the new dll's, (By say copying it another computer) RoadRunner will not start, period.
                            My Fiero Build Thread
                              I've noticed a few issues so far, and it may just be my setup(checking on my work computer, haven't tried in the truck yet), or the fact that the plug-ins need to be updated.
                              The music progress slider isn't working, or any slider for that matter
                              iLists don't seem to be working
