Embedding BlueSoleil - I give up
  • Embedding BlueSoleil - I give up
    Ok, I give up. I have BlueSoleil that came with my Bluetooth Dongle embedding in the Launch Section with this in the .ini file:
    [GENERAL]
    PATH = D:\Program Files\IVT Corporation\BlueSoleil\BlueSoleil.exe
    TryEmbeddedTimeOut = 5
    WindowSearchString=IVT Corporation BlueSoleil
    So why is it not embedding from a button in menu.skin that looks like this:
    B09,10,416,150,110,"LOAD;BlueSoleil.skin;IVT Corporation BlueSoleil;D:\Program Files\IVT Corporation\BlueSoleil\BlueSoleil.exe","IVT Corporation BlueSoleil"
    The skin opens, BlueSoleil opens, but it is not embedded?
    Any Help appreciated.
    RodW
    2007 Toyota Hilux with a CarPC..
    Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
    OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
    First of, you string is not right.
    The green part you only need for is road runners voice announcment.
    The red part is the WINDOW NAME. Remove those 2 " around the name.
    B09,10,416,150,110,"LOAD;BlueSoleil.skin;IVT Corporation BlueSoleil;D:\Program Files\IVT Corporation\BlueSoleil\BlueSoleil.exe;IVT Corporation BlueSoleil"
      Thanks, I'll give it a go. Seems the code I copied as a starting point was wrong to start with!
      EDIT : Fixed it, I had also used a comma instead of a semicolon which you had picked up.
      RodW
