*** NEW MJS BUILD OF RR *** (Resume Test 3)
  • *** NEW MJS BUILD OF RR *** (Resume Test 3)
    i need my testers....
    In the effort of continous improvement...
    I have found a few more bugs/issues in RR
    NONE of these where directly reported to me
    I was messing with RR, and discovered a few small things
    plus i wanted some other things
    *** POWER MANAGEMENT - Re-written a bit ***
    (need a tester or two, how has to touch thier screen on resume, to get resume)
    * FIXED - incorrect HD Radio DATA, RDSNAME, was returning incorrect data, it now returns CALL SIGN of HD Radio STATION.
    * FIXED - incorrect HD Radio DATA, RDSTEXT, now returns the stations "Tag line".
    + Added new RR.INI Option: "debugfresh=true/false", this will cause a rename of "debug.txt" to "debug.old" and a new "debug.txt" to be created on EACH RUN (REALLY helpfull, plus no huge debug.txt files anymore).
    + Added new RR.INI Option: "hdvolume=x (x=0-90)", this is the PREAMP volume, dont use this option, unless you need it, it defaults at 75, which i think is optimal. this is not needed to be added in RR.ini, the default is in play.
    SPECIAL: (do not add these to rr.ini, unless needed)
    these two options should not be normally used, I added in a manditory 2 seconds at sleep and resume, the sleep allows the file buffers to flush and events to finish, the resume allows hardware to settle in, specially USB devices.
    + Added new RR.INI Option: "resumedelay=x (x in seconds)", this will add extra time at resume before RR's "resumefromhibernate" procedure runs. (use only if needed, hense OPTION)
    + Added new RR.INI Option: "sleepdelay=x (x in seconds)", this will add extra time at sleep before RR's exits "prepareforhibernation" procedure. (use only if needed, hense OPTION)
    This code is OF COURSE built on 11/7 base, with ALL my previous changes.
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    I will test whatever you need tested
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
      you know where to find me
      mitch
      -Thanks
      Mitch
      www.rush2112.net
      Wind, Carry me home
        i'm testing this as well.. but felt it good to mention this is NOT a merged .exe like the 9/10 version is so backup your current .exe before testing.
        Live mp3Car Facebook Chat
          actually sonicx, you're not testing it as of NOW... you know where to find me
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
            Will give it a test in the next two days!
              OK Mitch tested the resume from ignition is working great and now the GPS indicators in DFX4.0 are working the only problem is still that hibernate and resume from SKIN results in no Sirius. I will email you the debug.txt file
                Dmistry, no Hibernate signal from your PC in the debug.txt
                what wierd OS u running, i do see a RESUMECRITICAL!
                make sure
                forcehibernate=false
                is in RR.ini
                also i uploaded test 3, to your FTP
                go with that, fixes a possbile double resume, which is FIXED in vista, but can happen on XP, and i run vista so i didnt see it till reading a debug.txt from sonicx and doing research on MSDN
                mitch
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  will be testing version 3 at lunch today for you and emailing you a new debug.txt file.
