10/13/08 Build of RoadRunner.exe
  • 10/13/08 Build of RoadRunner.exe
    **** SEE STICKY **** for newest files!!
    This should be the last build I do, unless there is a major bug.
    I would consider more "changes" if someone wants something and it makes
    sense, and i got some time to do em, and they can test what the changes.
    Im not gonna ask GUINO to make changes everyday. I can build them up... then see...
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    10/10/08
    + Added skin command "RTUNE" (see documentation file: MJS RR Skin Commands.txt)
    + Added skin label "ACTIVESOURCE" (see documentation file: MJS RR Skin Commands.txt)
    + Added USER variable "ACTIVESOURCEID" (see documentation file: MJS RR User Variables.txt)
    * Changed to USER variable "ISUNITS"  - International Standards: set "true" for Metric, "false" for English (On The Fly Changes)
    This is EXE only, I will update the installer.
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    thanks a lot for this new version, specially for "ACTIVESOURCE" and "ACTIVESOURCEID" very handy..
    BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
    RRTube ==> [View/Download Youtube Videos]
    WifiMan ==> [Wifi Manager]
    RRec ==> [Audio Capture]
    If You Want To Be Given Everything, Give Everything Up ...
    Bird York -- In The Deep --
      is possible have the new source code?
        there is NO new source code to give out, i dont have it. At this point, Gunio has the source... i think it pointed out somewhere, right now its not "open source"
        if there is specific something you want to do... i would suggest you do it in the 11/07 source, then work with me, and i can see if it all makes sense, and merge it with mine, then send it to guino... i cant think of any really easy way...
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          i just moved the UNICODE posts to a new thread
          http://www.mp3car.com/vbulletin/road...de-issues.html
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
            is there a skin commands.txt available for this mitch?
              take a look in the DOCUMENTATION directory
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                One major problem I have with this, is the HD Radio does not resume from a standby.
                And YES, the HD Radio has ful power when the pc comes out of standby. Can you check this and find a resolution?
                  My directed unit resumes just fine.
                  Live mp3Car Facebook Chat
                    That's the one I have, but no go after standby.
                      MGD, DEBUG, DEBUG, DEBUG
                      enable your hd radio debugging
                      review...
                      using usb to rs232 deally?
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        Is it just me or does this version of the RoadRunner.exe have blank channels on XM using DFX4.0?
                        I'm using an older version of the .exe but it doesn't have the logo in the middle so I tried this one, but can't use it cuz my XM channels are blank.
                          probably needs to build the cache. And as of yesterday Sirius mucked up all the XM and Sirius stations anyways.
                          1.9in x 2.9in -- 47mm x 73mm
                            There was a major channel update 2 days ago. DFX 4.0 doesn't have the sat rad message screens set up so you won't know what's it doing.
