Help with XM, preview no sound or nothing at all...
  • Help with XM, preview no sound or nothing at all...
    I'm using Simplistique skin and the mp3car XM adapter, everything use to work fine with the old version of roadrunner. My hard drive crashed and had to re-install everything again.
    Now using the new Roadrunner version can't get XM to work.
    The driver got installed, no problems.
    If I start roadrunner and go directly to XM, I can see the preview but no sound.
    If I get out and go to music then go back to XM, the music will mute as is supposed to, but I can't see the XM preview all I see is the playlist from music.
    If a reboot roadrunner and go directly to XM, I'll see the XM preview with no sound again, and keeps repeting.
    Any help will be greatly appreciated.
    Mod with a purpose and enjoy the ride
    Mick300ZX.net
    Cardomain
    which version of RR ?
    Live mp3Car Facebook Chat
      Version 1.0
      Mick300ZX.net
      Cardomain
        what is the DATE of the release? There isnt a such thing as version 1.0 as RR uses dates to specify version. Your best bet is to install RR using the new installer... switch to the included skin file and see if you can get XM working.
          I went to the roadrunner icon properties and under version says 1.0.
          How can I check which date mine is?
          Mick300ZX.net
          Cardomain
            when you start RR with the default skin the splash screen will have a date.. thats the date you need. If you're not using the default skin (BMV2) then check your existing skin fora label thats named "RRVER". That will have the date too
              Something to check, can you get your XM hardware to work with Satamp?
              If you don't know what I'm talking about you can download it here; http://www.rush2112.net/index.php?in...=SatAmpIII.zip
                Thanks, I'll check tonight.
                Did not know about this. Will try it to see if it works with it when I get a chance. Thanks!
                Mick300ZX.net
                Cardomain
                  i would use XMID to test
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Sun, Come shine my way
                  Wind, Carry me home
                  The piece of me that died
                  Will return To live again
                    Link to get it? I'll try both
                    Mick300ZX.net
                    Cardomain
                      same place... my site
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        The date is 10/10/08
                        I did re-install roadrunner with the new installer. I haven't try XM yet, I'll do it tomorrow, I have the PC in the house. But while trying all the features, when I try to play videos, no matter what skin I'm using (tried 3 so far) the computer re-boots by itself. It has something to do with winamp, I tried to play the videos just using winamp and it does the same thing. I have reinstalled winamp 4 times already and nothing. Any ideas?
                        Mick300ZX.net
                        Cardomain
                          What about trying a different video player? Like media player classic?
                            Just tried it and does the same thing. After the PC reboot I got a message that driver VIA/S3G CLE66 cause the system to be unstable. I'm going to re install the board drivers and see what happens.
                            Update: Reinstalled VIA/S3G driver and it got fix. Now I'm going to try and see if my first problem XM radio got fixed.
                            Mick300ZX.net
                            Cardomain
                              For some reason, I'm not able to install this player in my car PC, It did install in my Home PC.
                              Well... After installing a fresh version of roadrunner, now I don't even see the XM preview, as I used too before I attempted the fix.
                              Any ideas?
                              Mick300ZX.net
                              Cardomain
