Road runner and Navigator problem?!
  • Road runner and Navigator problem?!
    I'm having one problem with this newest version RR. When i press Navi it loads Navigator and docks it, Which is fine. But when i go into another section and then back into Navi it will load a second instance of Navigator and so on for however many times i go back and forth.
    I'm clearly missing something quite simple? i didnt have this problem before installing the newest version of RR. does anybody know how to stop it loading navigator over and over...
    nobody had this problem of road runner opening a program over and over?
      Considering over 95% of the community uses either iGuidance or Garmin, probably not.
        ....mmm maybe i'll swap to one of those then! lol
        but that said, i do find it strange as it worked fine for a few years, until i upgraded RR to the latest version.
          If you like it though, I understand those frustrations.
            If it re-opens your app, then your app is not embedding. It may look like it is since it is sized and positioned correctly, but it is not captured in RR. If it was it should not open twice.
            -InfinitiPC
              Okay i have attempted to embbed iGO8 with bad luck :/ I finally finished all the configs and its all good now, just need to be careful while using it cause the old one stays running under
              If someone could point the way correctly how can i just make it so that it doesnt launch new session everytime i goto "GPS"
              Thanks!
                Aaah! Forget about that, ill make a packet for iGO8... The skin with README file what to edit etc...
                Just tought that someone might alrdy done this...
