RoadRunner, Vista and you (Audio thread)
  • RoadRunner, Vista and you (Audio thread)
    so.. who is using RoadRunner on vista? (besides me)
    I have created a completely new control code in RR for Vista Audio control
    not just the Master Volume, but control for any other PLAYBACK connection to the "speakers"
    I have written a quick program, to evaluate you're vista audio system
    one thing of note, vista audio is NOTHING like XP audio, its much better
    its great that MS finnally dumped the old audio system.
    every vista audio system can be unique, especailly with fully taskable connectors!
    try this program out, and lets see some results
    tell me what is your audio system...
    example: (mine)
    Realtek HD Audio (ALC882)
    Code:
    [Speakers]    - Volume:18 - Mute:False
    Line 1 - [Front Green In]  	-> Mute=False | Volume=0
    Line 2 - [Rear Blue In]  	-> Mute=True | Volume=15
    Line 3 - [Front Pink In]  	-> Mute=False | Volume=0
    Line 4 - [Rear Pink In]  	-> Mute=False | Volume=0
    Line 5 - [Rear Grey In]  	-> Mute=False | Volume=0
    Line 6 - [Rear Orange In]  	-> Mute=False | Volume=0
    Line 7 - [Rear Black In]  	-> Mute=False | Volume=0
    Line 8 - [Rear Green In]  	-> Mute=False | Volume=0
    Line 9 - [CD Audio]  	-> Mute=False | Volume=0
    I have also did some documentation, on how to use in RR
    please read the text file, and any questions to it I can try to answer
    I think I wrote it easy enough to understand
    myself and blk02si have done Vista testing so far
    also guino did a bit too
    some xp tests where also done (to make sure i didnt break anything)
    thoese passed
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    i use RR with vista for a while, never had any problems at all with audio in RR and tested it with multiple systems with all the flavors of vista.
    Maybe cause I RTFM? When I get a chance I will try ur prog out.
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
      john, prior to last release there is NO way audio worked in RR for vista
      even if u did the hack of setting mastervolumemap=-1 (which isnt good anyway)
      i dont think if you ran RR in XP compatible mode it would work right
      -Thanks
      Mitch
      www.rush2112.net
      Wind, Carry me home
        Actually mitch, in many machines all you had to do was set XP compatibility mode -- It didn't allow to control the actual MASTER volume, but it would control the application volume (which was basically the same if you left the master volume all the way up). Anything else was incredibly dependent on your audio drivers though. This is definitely a big step up.. specially considering that newer windows versions such as Windows 7 will also use the same improved audio API.
        This is all I have on my machine (stupid HP machine):
        Code:
        [Speakers]    - Volume:50 - Mute:False
        Line 1 - [PC Beep]  	-> Mute=False | Volume=80
        Ride Runner RR's Myspace
          IC
          guino, is that a laptop or desktop?
          Mitch
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
            Good job Mitch its about time we start getting some Vista surport. Now I can reinstall vista and dump this XP crap.. Anyway when I had Vista installed I could not get the WiFi part to work in DFX4. have you been able to get it to work..
              I was talking at lunch about my current install and my coworkers were telling me I should use Win7 in my car. Might move to Vista soon, though.
              My Install : '08 Saturn Sky In-dash
                a lot of us can't run vista as it requires so much horse power. Win 7 demands about the same system requirement? I can run xp with my current system.
                  Windows 7 boots up 20% faster, and is much more optimized. It also takes all the crap out of Vista and makes them free addons.
                  Fair warning though Windows 7 is NOT public yet. If you have it, you are a beta tester or pirated it. If you pirated it, then that is illegal and any discussion of it will result in a ban on this forum. If you are a beta tester and install it in your car as well, you're breaking your beta agreement which is illegal as well.
                  1.9in x 2.9in -- 47mm x 73mm
                    The WiFi control in Vista/Win7 is quite different from XP.. I'm pretty sure that feature/plugin it'll have to be redone.. but I'm pretty sure it can be done too.
                      Been testing this with mitch, and have a build based on x64 vista that is working perfect!
                      Mitch did a VNC session on my PC to play with the code, was quite interesting watching him work.
                      Keep up the great work guys, as my next carpc will run vista (well tiny vista anyway )
                      Any more testing needed let me know.
                        What about if your running 2 sound cards? Will this work with 16 channels?
                          So does this mean that RR volume control will work in vista now? I'm just trying to get RR on my vista PC but no volume control. Using the program I get
                          Speakers / Headphones - Volume:100 Mute:False
                          Line 1-Speakers Mute=False Volume=91
                          What does this mean? Can anyone help me out here?
                          [||||||----] - 60% Complete
                            Never mind i'm dumb but i think I figured it out.
                              So code for Windows 7 is Vista for now on. Since most are going to dump vista for Windows 7 anyway and Windows 7 and Vista share a alot of the same features....
                              New Age Garmin - Skin for RR
