Byvar and LoadIMG problem
  • Byvar and LoadIMG problem
    Hi,
    i search for a solution since ~3 days for this Problem:
    I save a Variable to skin.ini and this Variable should switch between two Images on the same Position, with the Timer. But this does not work with Loadimg, IMG and LDImg.
    for example, my exectbl.:
    "TIMER","test",AUDIO_BROWSER.SKIN
    "test","BYVAR;Testswitch;Switch1<<Switch2"
    "Switch1","LoadIMG;232;120;80;80;$DisplayIMG1_on$; out"
    "Switch2","LoadIMG;232;120;80;80;$DisplayIMG1_off$ ;out"
    in the AUDIO_BROWSER.SKIN are the Buttons to set the Variable "Testswitch".
    But this works only once after Skinstart. When i change the Variable and reload Roadrunner, the other Image be displayed.
    I hope, my English is readable, Christmas Greetings from Germany and Babelfish...
    1-Did you add a TMR,X definition to audio_browser.skin ?
    2-What are the values of DisplayIMG1_off and DisplayIMG1_on ?
    3-Be sure there's nothing else defined where your image will be displayed.
    It should work with LOADIMG and LDIMG -- the only difference between the two is where the image is. If you post your audio_browser.skin it would be easier to understand it.
    Ride Runner RR's Myspace
      Hi,
      audio_browser.skin
      RoadRunner Skin
      RRScreen audio_browser
      audio_player_OFF.png,audio_player_OFF.png,audio_pl ayer_ON.png,audio_player_ON.png
      TMR,4
      B,227,2,29,45,"SAVETOSKIN;testswitch;1",
      B,198,2,29,45,"SAVETOSKIN;testswitch;0",
      B,247,548,99,32,"SEARCHFILES",
      B,260,127,77,57,"SELECT",
      B,1,1,72,53,"RELOADSKIN",
      B,2,254,102,199,"Shortcuts-Audio",
      B,278,374,67,61,"BROWSE",
      B,276,475,60,59,"CLEARLIST",
      B,277,259,66,63,"BACK",
      B,273,188,69,60,"ADD1",
      I,129,120,90,90,"CUSTOMFOLDERINDICATOR"
      I,741,1,66,58,"MASTERMUTE"
      I,77,58,30,33,"CUSTOMNEXTINDICATOR"
      I,14,58,30,33,"CUSTOMPREVINDICATOR"
      I,50,59,27,28,"CUSTOMPLAYINDICATOR:B"
      I,320,3,47,47,"ONLINE"
      I,740,59,60,37,"REPEAT"
      I,690,58,50,38,"SHUFFLE"
      L,129,119,90,90,0,0,0,12,"Arial","EXEC;Setdisk1||= ",
      L,149,216,90,90,0,0,0,12,"Arial","EXEC;Setdisk2||= ",
      L,156,308,90,90,0,0,0,12,"Arial","EXEC;Setdisk3||= ",
      L,149,400,90,90,0,0,0,12,"Arial","EXEC;Setdisk4||= ",
      L,128,492,90,90,0,0,0,12,"Arial","EXEC;Setdisk1||= ",
      L,135,185,97,17,255,255,255,10,"Tw Cen MT:B","=$DisplayText1$","CENTER"
      L,149,281,97,18,255,255,255,10,"Tw Cen MT:B","=$DisplayText2$","CENTER"
      L,150,373,97,18,255,255,255,10,"Tw Cen MT:B","=$DisplayText3$","CENTER"
      L,141,465,97,18,255,255,255,10,"Tw Cen MT:B","=$DisplayText4$","CENTER"
      L,120,557,97,18,255,255,255,10,"Tw Cen MT:B","=$DisplayText5$","CENTER"
      L,354,122,377,26,116,116,116,16,"VAGRounded BT","DLPATH","SCROLL-LEFT"
      L,74,31,76,25,255,255,255,12,"Arial:B","TIME","LEF T"
      L,74,7,76,22,255,255,255,12,"Arial:B","TODAY","LEF T"
      L,695,6,50,26,255,255,255,12,"Arial:B","VOLUME","R IGHT"
      L,134,64,535,36,0,0,0,24,"Urban Sketch:B","TAGARTIST||=: ||TAGTITLE||= (||TRACKTIME||=)","SCROLL-CENTER"
      L,282,389,63,32,255,255,255,12,"Arial:B","=ENTER",
      L,278,493,63,32,255,255,255,12,"Arial:B","=CLEAR",
      L,288,275,47,28,255,255,255,12,"Arial:B","=ROOT",
      L,288,201,47,37,255,255,255,12,"Arial:B","=ADD",
      L,257,552,83,21,255,255,255,12,"Arial:B","=SEARCH" ,"CENTER"
      L,279,142,47,32,255,255,255,12,"Arial:B","=NEW",
      IL,DL,transparent.bmp,sel.bmp,,0,50,60
      S,353,152,378,433,0,0,0,138,170,153,116,116,116,11 6,116,116,255,0,0,255,255,255,false,20,"VAGRounded BT"
      END
      ExecTBL.ini
      "ONSKINSTART","PLAYSTATUS||RELOADLIST"
      "Switch1","LoadIMG;1;120;80;80;$DisplayIMG1_on$;ou t"
      "Switch2","LoadIMG;1;120;80;80;$DisplayIMG1_off$;o ut"
      and skin.ini
      backgroundfolder=backgrounds
      background=C:\Program Files\Road Runner\Backgrounds\\Sunset Clouds.jpg
      Album Browser - Display Folder
      Disk1:
      Folder1=F:\
      DisplayText1=USB STICK
      Disk2:
      Folder2=C:\
      DisplayText2=HDD C:
      Disk3:
      Folder3=D:\Musik\
      DisplayText3=Music
      Disk4:
      Folder4=E:\
      DisplayText4=CD/DVD
      testswitch=0
      The fat marked is for the "Imageswitch-Function". On the position for the Images is nothing else defined.
      Thanks for your help!
        The problem is a simple misunderstanding of the savetoskin function -- it ONLY saves to the ini file, it DOES NOT set the variable (but RR loads it from the ini when reloading the skin). All you have to do is use setvar after savetoskin and you'll be done..
        Code:
        B,227,2,29,45,"SAVETOSKIN;testswitch;1||SETVAR;testswitch;1",
        B,198,2,29,45,"SAVETOSKIN;testswitch;0||SETVAR;testswitch;0",
          Oh, so easy....
          Thank you! Now it goes.
          I wish a good Slide in 2009
            I test
            Hey,
            I test a skin based on the toxic000 exemple :
            I want to create a screen with twelve button how can run twelve different command .
            Each button has an indicator status (red=off;green=on)
            I can set on off on the same screen ; I read in the skin.ini file
            the testswitch# variable :
            skin.ini
            Code:
            [Configuration Visualisation]
            DisplayText1=Maison
            testswitch=1
            DisplayText2=Bateau
            testswitch2=0
            DisplayText3=Voiture
            testswitch3=0
            DisplayText4=Garage
            testswitch4=1
            Exectbl.ini
            Code:
            ****************** BUTTON TOGGLE **************************
            "TIMER","test||test2||test3||test4",DETECT_POI.SKIN
            "Switch1","LoadIMG;18;193;137;16;$DisplayIMG1_on$;out"
            "Switch2","LoadIMG;18;193;137;16;$DisplayIMG1_off$;out"
            "test2","BYVAR;Testswitch2;Switch3<<Switch4"
            "Switch3","LoadIMG;178;193;137;16;$DisplayIMG2_on$;out"
            "Switch4","LoadIMG;178;193;137;16;$DisplayIMG2_off$;out"
            "test3","BYVAR;Testswitch3;Switch5<<Switch6"
            "Switch5","LoadIMG;337;193;137;16;$DisplayIMG3_on$;out"
            "Switch6","LoadIMG;337;193;137;16;$DisplayIMG3_off$;out"
            "test4","BYVAR;Testswitch4;Switch7<<Switch8"
            "Switch7","LoadIMG;18;287;137;16;$DisplayIMG4_on$;out"
            "Switch8","LoadIMG;18;287;137;16;$DisplayIMG4_off$;out"
            detect_poi.ini
            Code:
            RoadRunner Skin
            RRScreen F-CNS(800X600STRETCHED)"BROWSER"
            INC,BottomButtons.txt
            TMR,4
            IMG,380,133,55,50,"MenuIcons\voiture.png",OFF
            IMG,380,133,55,50,"MenuIcons\voiture.png",DOWN
            IMG,380,133,55,50,"MenuIcons\voiture.png",ON
            IMG,220,132,55,50,"MenuIcons\bateau.png",OFF
            IMG,220,132,55,50,"MenuIcons\bateau.png",DOWN
            IMG,220,132,55,50,"MenuIcons\bateau.png",ON
            IMG,57,228,55,50,"MenuIcons\garage.png",OFF
            IMG,57,228,55,50,"MenuIcons\garage.png",DOWN
            IMG,57,228,55,50,"MenuIcons\garage.png",ON
            IMG,58,134,55,50,"MenuIcons\maison.png",OFF
            IMG,58,133,55,50,"MenuIcons\maison.png",DOWN
            IMG,58,133,55,50,"MenuIcons\maison.png",ON
            IMG,647,113,128,129,"MenuIcons\maison.png",
            B,640,330,150,52,"SAVETOSKIN;testswitch;1||SETVAR;testswitch;1",
            B,489,331,148,49,"SAVETOSKIN;testswitch;0||SETVAR;testswitch;0",
            L,71,80,357,35,255,255,255,23,ARIAL:B,"=TWELVE COMMAND","SCROLL-CENTER"
            L,650,348,128,19,255,255,255,18,ARIAL:B,"=OFF","CENTER"
            L,497,348,131,19,255,255,255,18,ARIAL:B,"=ON","CENTER"
            L,501,166,139,26,255,255,255,16,ARIAL:B,"=LATITUDE:","LEFT"
            L,501,192,139,26,255,255,255,16,ARIAL:B,"= ||GPSLAT","LEFT"
            L,501,111,139,26,255,255,255,16,ARIAL:B,"=LONGITUDE:","LEFT"
            L,501,139,139,26,255,255,255,16,ARIAL:B,"= ||GPSLON","LEFT"
            /Definition visualisation on off des boutons
            L,491,404,299,44,0,0,0,12,"Arial","EXEC;Setdisk1||= ",
            L,519,75,246,33,255,255,255,18,ARIAL:B,"=$DisplayText1$","SCROLL-CENTER"
            L,17,237,138,33,255,255,255,18,ARIAL:B,"=CMD4","SCROLL-CENTER"
            L,336,144,138,33,255,255,255,18,ARIAL:B,"=CMD3","SCROLL-CENTER"
            L,178,143,138,33,255,255,255,18,ARIAL:B,"=CMD2","SCROLL-CENTER"
            L,17,142,138,33,255,255,255,18,ARIAL:B,"=CMD1","SCROLL-CENTER"
            L,515,285,246,33,255,255,255,18,ARIAL:B,"=$DisplayText1$","SCROLL-CENTER"
            L,580,413,137,28,255,255,255,16,"ARIAL:B","=Exec SetDisk","CENTER"
            /, B, X, Y, W, H, COMMAND;COMMANDCODES, TOOLTIP
            B01,489,279,300,45,"SELECT","SELECT"
            B,300,521,99,80,"PLAY",@STOP||PLAY@
            B,398,521,101,80,"NEXTTRACK",
            B,203,521,99,80,"PREVTRACK",
            B12,596,521,99,80,"VOL+",""
            B11,500,521,99,80,"VOL-",""
            B09,102,521,100,80,"EXIT",""
            B90,0,520,101,80,"ESC",@LOAD;MENU.SKIN@
            /, I, X, Y, W, H, CODE;INDICATORCODES
            I01,698,521,107,80,"MASTERMUTE"
            END
            Actually , I can just set on or of the first command button (CMD1) , with the "savetoskin" command .
            If I push on the CMD1 button , I want to configure this command on/off ,
            if I push on the CMD2 button I want to configure the CMD2 button , etc...
            How can I do that please ?
            My hope is to have twelve run cmd possibility .
            Is it possible with the RREtended plugin or an other ?
            I have a second problem with .png files on button who are hided .
            I can't see that:
            Code:
            I can see that picture :
            Code:
            Any idea ?
            Thanks .
              To have a button toggle on/off on button command, just do this:
              BYVAR;Testswitch1;SETVAR;Testswitch1;1<<SETVAR;Tes tswitch1;0"
              Q#2:
              Add this line:
              IMG,58,134,55,50,"MenuIcons\maison.png",OUT
              so you can see the image.
              Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
                Solve my first problem . Pictures was hided because I had not a command on my buttons !
                But this command don't read my skin.ini file .
                If you try my skin , when I push on on/off buttons, I enable or disable and see my on.gif or off.gif indicator .
                Add this line:
                Change nothing for the moment .
                On the screen under these lines , if i push on first left button (Maison), I should like to see on right
                with the top of the buttons on and off the same label (Maison) and the button on run (on) or kill a command .
                If it is possible with a toggle button without read the skin.ini file i agree this option .
                I had found this possibility :
                B,295,517,100,81,"PLAY",@STOP||PLAY@
                Is it a solution ?
                  So if I understand this right...you want the button to toggle on/off based on state and update the image indicator that is defined in skin.ini?
                  I think this will work...
                  Button:
                  "BYVAR;Testswitch1;TESTSWITCHOFF<<TESTSWITCHON "
                  ExecTBL
                  "TESTSWITCHOFF","SETVAR;Testswitch;1||LoadIMG;18;1 93;137;16;$DisplayIMG1_off$;out"
                  "TESTSWITCHON","SETVAR;Testswitch;0||LoadIMG;18;19 3;137;16;$DisplayIMG1_on$;out"
                  You don' have to read the ini and you can set the state using variable in runtime. skin.ini just initializes and populates your variables on rr/skin startup. you can change the values in runtime using commands like SETVAR, SETVARBYCODE, etc...
                    FYI - might want to read up on using custom indicators and the BYIND command. Might yield better results for you.
                      Tanks Sal R for your help .
                      I had doing some test with skintool ,
                      and if i use that line :
                      BYVAR;Testswitch;SETVAR;Testswitch;1<<SETVAR;Tests witch;0
                      I have a good issue , but not on the screen !
                      I test your second option and you return the result,
                        cool.
                          Button:
                          ExecTBL
                          I have the same issue , don't run on the screen but run out the screen with skintool !
                          RoadRunner Skin
                          TMR,4
                          IMG,647,113,128,129,"MenuIcons\maison.png",OUT
                          B,640,330,150,52,"SAVETOSKIN;testswitch;1||SETVAR; testswitch;1",
                          B,488,331,148,49,"SAVETOSKIN;testswitch;0||SETVAR; testswitch;0",
                          L,650,348,128,19,255,255,255,18,ARIAL:B,"=OFF","CE NTER"
                          L,497,348,131,19,255,255,255,18,ARIAL:B,"=ON","CEN TER"
                          L,501,166,139,26,255,255,255,16,ARIAL:B,"=LATITUDE :","LEFT"
                          L,501,111,139,26,255,255,255,16,ARIAL:B,"=LONGITUD E:","LEFT"
                          L,519,75,246,33,255,255,255,18,ARIAL:B,"=$DisplayT ext1$","SCROLL-CENTER"
                          L,17,237,138,33,255,255,255,18,ARIAL:B,"=$DisplayT ext4$","SCROLL-CENTER"
                          L,336,144,138,33,255,255,255,18,ARIAL:B,"=$Display Text3$","SCROLL-CENTER"
                          L,178,143,138,33,255,255,255,18,ARIAL:B,"=$Display Text2$","SCROLL-CENTER"
                          L,17,142,138,33,255,255,255,18,ARIAL:B,"=$DisplayT ext1$","SCROLL-CENTER"
                          L,521,285,246,33,255,255,255,18,ARIAL:B,"=$Display Text1$","SCROLL-CENTER"
                          B04,8,216,158,68,"BYVAR;Testswitch4;SETVAR;Testswi tch4;1<<SETVAR;Testswitch4;0",""
                          B03,329,123,158,68,"BYVAR;Testswitch3;SETVAR;Tests witch3;1<<SETVAR;Testswitch3;0",""
                          B02,168,123,158,68,"BYVAR;Testswitch2;SETVAR;Tests witch2;1<<SETVAR;Testswitch2;0",""
                          B01,6,122,158,68,"BYVAR;Testswitch;TESTSWITCHOFF<< TESTSWITCHON",""
                          /, Y, BACK SLIDER FILE PATH
                          Y01,"SLIDER_BATTERY\SLIDER_*.GIF"
                          Y02,"VSLIDERWOOFER\SLIDER_*.GIF"
                          /, S, X, Y, W, H, FORECOLOR R;RGB, G, B, BACKCOLOR R;RGB, G, B, SELECTED COLOR R;RGB, G, B, SELECT COLOR R;RGB, G, B, TRS, FONT SIZE;FONT, FONT NAME
                          S01,678,39,102,20,62,103,70,20,V,01," ",015,"GPSSIGNAL","GPS SIGNAL"
                          S02,506,244,269,22,121,203,411,27,H,02,"VSLIDERWOO FER\POINTER.GIF",15,"$SPEEDZONEMONITOR$",
                          I,668,6,21,21,"RM_1STAR"
                          I,692,6,21,21,"RM_2STAR"
                          I,716,6,21,21,"RM_3STAR"
                          I,740,6,21,21,"RM_4STAR"
                          I,764,6,21,21,"RM_5STAR"
                          I,70,7,52,25,"SHUFFLE"
                          I,13,7,50,25,"REPEAT"
                          I16,320,4,32,31,"HEADING"
                          I,124,7,54,25,"ONLINE"
                          END
                          This is my screen file .
                            I noticed a space in the button command in your skin file:
                            can you confirm that there is no space?
                              Hey Sal R,
                              I confirm you that I have no space before TESTSWITCHON .
                              Is ok ?
