coverjuke 1.51 embeding?
  • coverjuke 1.51 embeding?
    in the old v' was a file "load_cj.exe" that caused him to embed in RR skin Teknik2 but now he does't
    my question how i can embed and resize this v in RR skin?
    "CJ_LOAD","LOAD;coverjuke.skin;CoverJuke;$skinpath $coverjuke\coverjuke.exe;coverjuke
    this command don't work for me
    CJ now embeds without external scripts , a new update for this is being worked on , there are loads of changes that make it more carpc friendly so what the coverjuke thread in plugins section for updates when ready
    ENJOY
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
      sweet.. didn't know that until just now... i just tried it and yes sir it did embed correctly... Thanks
        please tell me what v' you use?
        and how you embed it in RR?
          sure... first, window name is "freeglut", not coverjuke... That's all u need to change. it should work... and if you want, u can get rid of clip area now ... just add application area instead...
          Code:
          "loadCOVERJUKE","LOAD;coverjukevideo.skin;!freeglut;$RRPATH$plugins\Coverjuke\coverjuke.exe;!freeglut"
            Code:
            thanks man!!!
            but it not resizeing properly
            coverjuke.ini
            width = 780
            height = 414
            and the "SENDKEY" command not working
            CJ_PREVALBUM","ACTIVATE;coverjuke||WAIT;0.1||SENDK EY;{LEFT}||SETTOPMOST;RR;TRUE"
            does't make any difference do you have any idea?
              man.. i don't know what you are doing with all that send key stuff... when embedding, width and height in coverjuke.ini are meanless.. Doesn't matter what you put in there... it will resize according to the application area you defined in a skin.. If you are using el camino's plugin, you have better luck posting there for your solution....
                Brandensin,
                When embedding using the same command as you, I get what looks like the title bar (in black) at the top of the application area. This causes the scroll bar of the application not to show. Are you having this issue as well?
                In picture, application area is defined below the top bar to the top of the button menu.
                  yes, i got that black area as well.. but i see everything... what scroll bar are you talking about? The one on the bottom you use to flip the album? you have to set the flag in config file to unhide it..
                    shoot... just confirmed, you are right.. i don't see the bar either... well.. no biggie... i don't use it anyway.... but it is weird..
                      yeh, I think I might send send Leb a message, maybe it can be fixed in the next update.
                        scroll bar is there , try it standalone not in rr , and you see the scroll bar it gets cut off when embedding.
                          Code:
                          Just for heads up, there's no space on ("!freeglu t") I was having probelm reaizing until I changed it. the winsppy helped sort out the confusion. Thanks though much help. The 1.52V embeds perfectly.
                          Did it.. Done it... now I got to keep the neighbors kids away!!
                            Code:
                            LOAD;coverjukevideo.skin;!freeglut;C:\Progam Files\RideRunner\Plugins\Coverjuke\coverjuke.exe;!freeglut
                            no commands in EXbl.ini or rr.ini
                              It doesn't embed "perfectly" but it's close. See my post above about the black bar at the top of the page, which cuts off the scroll bar. Anyway, this is due to how the application is written when it wants to go into fullscreen. Basically the Windows Title Bar sits over the Application, and when in full screen, it is just removed. I have been messing with skinbedder lately, and have gotten the black bar cropped out, but still no scroll bar. I may look into the ini's of coverjuke to see if I can reposition it somewhere. Also, in the config screen where you can choose what to send to an external audio player, it is backwards. "List of File" sends the folder path, and "Folder" sends a list of all the songs in the Folder, List of file works best for sending directly to Winamp.
