AutoIt + Hibernation = fail
  • AutoIt + Hibernation = fail
    Purpose:
    Using a PIC to read my encoded steering wheel buttons and output results through a serial port. AutoIT script reads serial port and performs RR commands.
    Problem:
    It works great as long as I don't use hibernate. When it comes out from hibernate the AutoIT script cannot communicate with RR. I tried exiting the AutoIT script and re-running the script the same problem exists. The only way to communicate with RR again is to exit RR and reload RR, or perform a cold boot.
    Question:
    Is there anything missing from the AutoIT script so it can communicate with RR after hibernation? Or would it be better to convert this to visual basic 6 extension to avoid the hibernation bug?
    PHP Code:
    serial port setup
    $MsComm1
    ObjCreate("MSCOMMLib.MsComm.1")
    $MsComm1.CommPort 4
    $MsComm1
    .Settings "9600,N,8,1"
    $MsComm1.Handshaking 0
    $MsComm1
    .InBufferSize 1024
    $MsComm1
    .InputLen 1
    $MsComm1
    .PortOpen 1
    $rr
    ObjCreate("RoadRunner.sdk") ; Open COM with RR
    _SerialOut
    ("z")  ; initialize serial port and wake up PIC
    While 1
        $message
    _SerialIn()
    $result=StringStripWS($message,8) ; removes white space CR LF
    If StringCompare($result,"MUTE") == 0 Then
            $rr
    .Execute("PLAY")
        ElseIf
    StringCompare($result,"FM/AM") == 0 Then
            $rr
    .Execute("PREV2")
        ElseIf
    StringCompare($result,"VOL-") == 0 Then
            $rr
    .Execute("VOL-")
        ElseIf
    StringCompare($result,"VOL+") == 0 Then
            $rr
    .Execute("VOL+")
        ElseIf
    StringCompare($result,"AUTOM") == 0 Then
            $rr
    .Execute("NEXT")
        ElseIf
    StringCompare($result,"MCAL") == 0 Then
            $rr
    .Execute("PREV")
        EndIf
    WEnd
    Func _SerialOut
    ($str)  ; Write to serial port function
    $MsComm1.OutBufferCount 0
        $MsComm1
    .InBufferCount 0
    If $MsComm1.PortOpen True Then
            $MsComm1
    .Output $str
    EndIf
    $MsComm1.InputLen 0
    EndFunc
    Func _SerialIn
    ()  ; Read from serial port function
        If
    $MsComm1.InBufferSize 1 Then
    Return $MsComm1.Input
    Endif
    EndFunc
    I don't see an error right now. But I don't have any problems using my AutoIt scripts (which interact with RR) after hibernate/resume. I didn't add any special commands.
    I know this doesn't really help, just wanted to say that from my experience it should work without problems.
