*** RR COM CleanUp Tool ***
  • *** RR COM CleanUp Tool ***
    Over the years of developing EVERY new build of RR caused a net set of Com Object registry entries in ones registry, making a small mess.
    every Com Object has a CLSID (A CLSID is a globally unique identifier that identifies a COM class object)
    well if you take a look you might have tons of RoadRunner.GPS and RoadRunner.SDK ones (a good tool to use is Com Explorer [ http://www.4dev.com/com/index.htm ] under EXE Servers)
    on a developing machine myself had 100+ sets, so I decided to research and learn how to prevent EVERY new build of RR from generating new CLSIDs, since we only need 1 set. it was quite easy, so from now on(unless major change to sdk/gps class) the CLSIDs will be constant no more registry mess
    BUT, we need to clean up the current mess...
    so i wrote a program, that will go though the registry looking for the two classes "RoadRunner.SDK" and "RoadRunner.GPS" and clean them (aka delete)
    the next time you run RR, the NEWEST CLSID will be created.
    the program is OF COURSE .net... post your count if > 25
    we'll see who wins
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Got an error
      you prob need to be a ADMIN or run as admin
      or do what it says grant it permission
      -Thanks
      Mitch
      www.rush2112.net
      Wind, Carry me home
        well i have 3
        ran smoothly and deleted with no problems , i even ran the app again to see, and now i have 1 after running rr again , so it dose exactly what it say's on the tin.
        Riderunner / Genesis
        Wifiman_NET:Version 1.0.0
          Did you actually take a picture like with a camera of your computer screen?
          1.9in x 2.9in -- 47mm x 73mm
            na early morning here eyes not open yet lol...
              I am and I did, still locked up.
                That error is also indicative of antivirus running preventing access to the registry.
                  Fixed my security policy issue.
                    had 35
                    2001 S10 ZR2
                    Chucks Skin - to old
                      Got only 7.
                        37 found here on my work comp...
                        Next in line: RRMedia v2.0
                        DFX 5.1.1 Skin
                        Appstore Link
                        My RideRunner Plugins
                        RRMedia
                        RRExtended
                        DFXVoice
                          Got a pathetic 6
                          OLD SYSTEM (DEAD)
                          Intel D945GCLF2 Dual Core ATOM
                          Lilliput 7" 629GL 2008 LED Backlight
                          BU-353 USB GPS Receiver / iGuidance / IGO8
                          M2-ATX Power Supply
                          RideRunner Front End / Various Skins
                          Windows XP SP3
                            - -Just found only 1- -
                            - -Take a good look at yourself while at the computer, if your in a t-shirt and talking [email protected] on the internet. Chances are you fall in the "Internet Tough Guy" catagory.- -
                              Only had 3 myself. Maybe Im not updating as much as I should
                              New Age Garmin - Skin for RR
