Command execute by an Indicator State?
  • Command execute by an Indicator State?
    Hi,
    I found nothing in the Forum and the Skin Commands.txt.
    I would execute a Command (defined only in execxtbl.ini) by an Indicator State in all/pre-defined Screens.
    How can I make that?
    Originally posted by toxic000 View Post
    Hi,
    check out "BYIND" in skin commands.txt
    Live mp3Car Facebook Chat
      Can I write simply "ByInd..........","Play.." with or without ,XXX.skin?
      Functions, as soon as the indicator goes on?
      I thought, this goes only with Buttons...
      I thought, I must write "!IndicatorXX","Play...". And this has no Function.
      Thank you, I will test it!
        You need to use BYIND to do this.
        "BYIND;YOUR INDICATOR;PLAY"
        replace the YOUR INDICATOR with the name of the indicator you have and then place the command after that.
          I test this at the moment- The line of the exectbl.ini:
          "BYIND;online;PLAY"
          And then in Network-attitudes from WinXP deactivate LAN Connection- Has no Function. Re-activate from LAN, and wait till the Indicator(I see the Picture-Indicator) was on, but also no Function.
            You need to put this line "BYIND;online;PLAY"
            in the skin where the indicator is located. For example, you have the ONLINE indicator in the AUDO_PLAYER.skin then you need to put "BYIND;online;PLAY" in the AUDIO_PLAYER.skin file.
              Okay. I have no success today...
              I have tested in menu.skin:
              I,320,3,47,47,"ONLINE"
              BYIND;online;PLAY
              No Success.
              "BYIND;online;PLAY"
              Also no Success.
              To test i deactivate and activate the LAN Connection. And switch to another Screens.
              Have you a example Skin File for me, where this work?
                BYIND is a command.. not an event. You can generate an event with a plugin/script or with a timer.. then have it execute byind... with a timer you'd have to put it on every screen or it would work only on the screen you add the timer...
                for instance:
                Code:
                in screen1.skin:
                TMR,10
                then in exectbl.ini:
                "TIMER","BYIND;ONLINE;GOOFF<<GOON",screen1.skin
                "GOON","BYVAR;ONLINE;NOWONLINE||SETVAR;ONLINE;1<<"
                "GOOFF","BYVAR;ONLINE;<<NOWOFFLINE||SETVAR;ONLINE;0"
                "NOWONLINE","PLACE HERE COMMAND TO EXECUTE ONCE WHEN SWITCHING FROM OFFLINE TO ONLINE"
                "NOWOFFLINE","PLACE HERE COMMAND TO EXECUTE ONCE WHEN SWITCHING FROM ONLINE TO OFFLINE"
                A script/plugin is still a better solution.
                Ride Runner RR's Myspace
                  OK,
                  thanks for your Explanation.
                  The Timer can i not use, i have a TMR in all Screens. And i can in one Screen just use only one Timer. Or is more possible? Like TimerPlay=3 ?
                    OK,
                    You can only have one timer per screen, but the same timer can run multiple commands... and you can tweak each command to run at different rates using variables..
