iLists not working
  • iLists not working
    The ilists are not working. The playlist shows but will not scroll.
    What am I doing wrong?
    using NEW RR, Tried with Carwings and New Age Garmin
    Any help is appreciated...
    New Age Garmin - Skin for RR
    Using the newest version of Ride Runner
      Direct X installed and USEDX=True in RR.ini... Searched couldnt find much else..
        can you make a debug log ? it should say something in it if it can't start DirectX..
        Ride Runner RR's Myspace
          attached is the debug.txt
          thanks for the help
            might wanna look into this,
            http://www.mp3car.com/vbulletin/road...rr-freeze.html
              "E"rror on InitDX: -2005532109 Automation error" -- there's definitely some missing component.. check that thread above... the DX7VB.DLL is installed with the installshield -- if you used it, in which case you may want to consider update/upgrade your DirectX install.
                thunder, i assume u used the installer?
                grab latest dx from microsoft
                and use the RideRunner installer
                mitch
                -Thanks
                Mitch
                www.rush2112.net
                Sun, Come shine my way
                Wind, Carry me home
                The piece of me that died
                Will return To live again
                  DX is definitely up to date. DL'd latest of MS website after I started having the problem. I will Reinstall RR and try that.
                    Reinstalled RR, ilists still not working in any skin. Carwings or New Age... reaching out for idea...
                    Here is a new Debug if it helps.
                      after running the DXDIAG test everything seems to check out fine with DX. Checked if DX7VB.DLL is installed and it is.
                        Can you try "regsvr32 dx7vb.dll" to see ? Something is definitely wrong when trying to initialize DirectX ... question is what exactly..
                          video card drivers maybe?
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
                            Just reg'd dx again, no go.
                            This all happened after I used some screen capture software. Let me work on this some and Ill get back to ya'll
                            thanks for the help.
                              OK now I feel like a moran, it was the screen capture software. It has a setting to disable or enable direct X for capturing. Well it disabled it. Enabled it and guess what, it works now.
                              Sorry for the trouble...
