Savetoskin-Command Question
  • Savetoskin-Command Question
    I must save to my Skin.ini the following Command:
    Code:
    BTN4=EXIT||LIST||PLAYAUDIOFOLDER1
    Before i tested with only one Command. Only Playaudiofolder1 would saved perfect. But with 3 Commands it saved only the first command.
    But i need the 3 Commands, that below black marked.
    Code:
    "SAVETOSKIN;$EDITBUTTON$;EXIT||LIST||PLAYAUDIOFOLDER1||...
    How can i make this?
    Use the string replace function of RRExtended to replace "|" w/ something like "@" that can be saved to skin.
    When recalling the command, replace "@" w/ "|."
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
      you mean:
      "RRStrings_StrRepl"
      Replaces text in a var with other text
      Syntax: "StrRepl;<Var>;<Text to replace>;<Replacement Text;<Return Var>"
      Example: "StrRepl;TrackPath;AC-DC;Metallica;Myvar"
      Result: MyVar = "D:\MyMusic\Metallica\Razors Edge\If You Dare.mp3"
      Thus i must write like in the example above, i think:
      "StrRepl;<var that opens the code like my first post>;@@;||;<what must stand here?>"
      This Code i must write in the skin.ini? What must i write in the <ReturnVar>?
      Thank you for your help!
        Thinking about it some more, I don't think you can use StrRepl here because it'll probably process "||" like the rest of RR.
        Only thing I can think of it is to do it via AutoIT...
          Toxic,
          Is there anyway to make the button command, just one command that you specify in the ExecTBL?
          Like:
          "B4CMD";"EXIT||LIST||PLAYAUDIOFOLDER1"
          then, u could do:
          "SAVETOSKIN;$EDITBUTTON$;B4CMD"
          maybe?
          edit:
          After looking over the skin commands, you might be able to use "++" in the place of "||"
          so maybe:
          "SAVETOSKIN;$EDITBUTTON$;EXIT++LIST++PLAYAUDIOFOLD ER1"
            Originally posted by ws6vert View Post
            Toxic,
            Like:
            then, u could do:
            maybe?
            Uuh, sometimes my exectbl.ini looks like a ...
            Your Tip was good, the Command PLAYAUDIOFOLDER1 now executes also the EXIT AND LIST.
            Thanks.
            Also Thanks to Sal R. Before, i had never looked in the RRextended Notes.txt. There are many good new Commands for me!
              HA!
              Your ExecTBL.ini has got nothin' on my ExecTBL.ini
                My ExecTBL.ini is about half the size of RideRunner.exe
                2001 S10 ZR2
                Chucks Skin - to old
                  Now your just wasting Mp3car server space... could have just pointed to your thread like this
                  Next in line: RRMedia v2.0
                  DFX 5.1.1 Skin
                  Appstore Link
                  My RideRunner Plugins
                  RRMedia
                  RRExtended
                  DFXVoice
                    What a showboat!
                      Actually, Chuck is wrong, its half the size of compressed RR, newer versions uncompressed are running around 3.2mb
                      Its not sooo big now is it...
                      DFX 5.1.1 Skin
                      Appstore Link
                      RRMedia
                      RRExtended
                      DFXVoice
                        SETVAR works with ||, SAVETOSKIN does not, but could be improved.
                        Ride Runner RR's Myspace
