RR 03-01-09 ... Couple more things..
  • RR 03-01-09 ... Couple more things..
    In this Version:
    -Added ONPBDBLCLICK event
    -Added "EQ" setting to the preset cmd to only load the EQ settings; example: "PRESET;ROCK;EQ" (load/save "ROCK".pst file -- EQ data only)
    -Added Left/Right IL swaping setting (ILSwapLR=T/F, runtime setable )
    -Added "HDARTIST" label, returns artist for CURRENT sub channel
    -Added "HDTITLE" label, returns title for CURRENT sub channel
    -Added "HDTRACKNAME" label, returns "artist - title" for CURRENT sub channel
    -Added "HDTRACKNAMEx" labels (x = 1 to 6); example: "HDTRACKNAME1" returns "artist - title" for HD1
    -Added Prevention in CheckResume if VideoON
    -Added Ddisplay # to vista input enumeration; example: SOURCE: Playback Input line #1: "Front Green In"
    -Added "SCREENSHOT" skin command; example: "SCREENSHOT;filename.bmp" or "SCREENSHOT;$picspath$mypic.bmp"
    -Improved EVAL command so strcomp can have a label code as the 1st parameter
    -Improved SAVETOSKIN works with ++ (to work as ||)
    -Fixed built-in Gamma State after resume
    -Fixed for hibernateaware=false only working once
    -Fixed incorrect effect on sliding into folders
    -Fixed "SETPATH" will now work with paths with no files in them
    -Plugin Manger, find / load sequence, plugins are found and immediately loaded, vs find them all, then load. It fixes a technical back end issue. there should be no noticeable change.
    Notes:
    -Thanks to Mitch and BlueZX3 for continuing work on this project.
    -It is RECOMMENDED to always use the Installer to update the software, it has the newest config and skin tools included.
    As always you can download it for FREE HERE
    Thanks for your support,
    Guino.
    IMPORTANT: a small bug has been found in RRCONFIG, the winamp path if not set to auto it will be corrupted
    edit rr.ini manually or just use AUTO
    winamppath=
    when set with NO path, its in AUTO mode, and RR will find winamp based on the winamp developer's recomendation to find winamp on a system
    -Mitch
    Ride Runner RR's Myspace
    SCREENSHOT = yes!
    Thx for the hardwork.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
      Thank you for the work! Great Program with great Programmers!
        great news thanks guys..
        BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
        RRTube ==> [View/Download Youtube Videos]
        WifiMan ==> [Wifi Manager]
        RRec ==> [Audio Capture]
        If You Want To Be Given Everything, Give Everything Up ...
        Bird York -- In The Deep --
          Broke something on Win7
          Installed the newest today on my Win 7 system, used the full installer, right over the top of my current config using DFX4.
          Anyway when starting up , RR has no control over winamp, I have to open the agent and press play on winamp, after that, RR has control over winamp.
          Still playing around with this any thoughts or suggestions?
          TruckPC - gutted, being used for test setup
          BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
          BlazerPC - Nexus 7 with Timur's USBROM
            Dave, offically, we're not supporting win7
            we have to do a major rewrite to RR, to fix alot of file location issues
            (this is why its not UAC compatible)
            just for vista
            and since win7 and vista are close sisters
            but in any case, nothing drastic is changed in this version of RR
            so if u got a win7 issue, welcome to keep it in its own thread... but for me to look at the issue, it has to happen on vista too
            cause i only got win7 on a virtual machine
            -Thanks
            Mitch
            www.rush2112.net
            Sun, Come shine my way
            Wind, Carry me home
            The piece of me that died
            Will return To live again
              fine,
              just letting you guys know something that used to work is now broke.
                Winamp Automatic/Manual
                I noticed that I had to change the Player Setup setting for Winamp in RRCONFIG from Winamp(Manual) to Winamp(Auto) for the players path to show after running the installer. This is the first time I have had to do this after an update.
                ...JJG
                  That is because the config was finally updated. If winamp was installed prior to the running of the config, it will look to see if it can locate winamps path, other wise it will set itself to manual or if you previously spec a path.
                  This rr version also has the same feature built in, if your using the wa as the player.
                  Next in line: RRMedia v2.0
                  DFX 5.1.1 Skin
                  Appstore Link
                  My RideRunner Plugins
                  RRMedia
                  RRExtended
                  DFXVoice
                    I was thinking that this was DaveDogs issue with his install...
                    Winamp would not load with RR till I changed this, which made sense, Path was just "Winamp".
                    ...JJG
                      Jebus, thanks, YOU FOUND a bug in RRCONFIG
                      Blue will FIX
                      it does overwrite the PATH incorrectly, when done manually
                      even if u just open RRCONFIG, and change something else, it WILL corrupt the setting
                      THis needs to be fixed ASAP
                      i dont have a prize to give ya
                      just set it to AUTO
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        Cool, Now where's my REP points!
                        ...JJG
                          does not function on my Skin.
                          In my Picviewer Screen i try without a empty File and only Folders, it show nothing. So it is like before Update, i need a empty File to show the Folders.
                          I use the old/normal Picviewer Screen, with only a simple DL $picspath$ and without any Imageviewer Program.
                          On my Audio_Browser Screen i could not yet tested.
                          -Or is this only for the Command "setpath"?
                            not here toxic, i got a folder, and inside that folder, is just folders
                            setpath;e:\_HW Projects\
                            set it to that folder, and i see the other folders
                            i just tried it on
                            Jan09 build = DONT WORK
                            March09 build = WORKS
                            -Thanks
                            Mitch
                            www.rush2112.net
                            Wind, Carry me home
                              ...JJG
                              yep, that was it, but since RR doesn't support Win 7....
