Im geting black vertical line - FAQ
  • Im geting black vertical line - FAQ
    I haven't been able to get Ride Runner to run correctly after using the new install. The splashscreen for my skin shows then I just get a thin black line on the screen. I can see that RR is running on the task list. Any ideas?
    Sounds like a rr.ini setting changed like fastmode=-1 (switched to something else).
    Ride Runner RR's Myspace
      I checked and fastmode is set to -1. I tried 0 and 1 but neither worked. I've attached a screenshot and the debug output if that's helpful. Thanks for the help.
        MJO, its all in the debug
        3/7/2009 3:21:51 PM: LoadSkin: C:\Program Files\RideRunner\Skins\DigitalFX 4.0\
        3/7/2009 3:21:51 PM: Plugin Manager: loading SkinDir Plugins...
        3/7/2009 3:21:51 PM: Plugin Manager: loading SkinDir Plugins Completed.
        3/7/2009 3:21:51 PM: ERROR loading image file(s) for: menu.skin
        is that path right to ur skin? is menu skin images there? (likely not, since u got the ERROR..)
        let me guess u install dfx4 and its in "Road Runner" Dir (just a guess)
        -Thanks
        Mitch
        www.rush2112.net
        Sun, Come shine my way
        Wind, Carry me home
        The piece of me that died
        Will return To live again
          The path is correct and the skin images are there (menu_OFF.png, menu_ON.png). Is it possible there is some dll that isn't registered correctly or something? I am getting the same error with the default carwings skin. Also, when I goto my old Road Runner directory and try to run I get that same problem, even though it was working prior to the install.
          thanks.
            actualy that error can be GENERATED from alot of different reasons
            if a bitmap fails to create
            which if fastmode = -1, could be GDI issue
            which there is gdi, dlls
            you did use the installer right?
            if so that dll would be registered
            GDIPlusWrapper.dll
            AND u have to have GDI+ on ur system, which it IS in normal XP
            but if u "lite"d the os...
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              FYI
              the Microsoft dll is
              gdiplus.dll
              which i do stick in the RR dir
              but it prob already is on ur system
              in system32
              ALSO WinSxS (Side by Side) should handle this
              and the correct dll should load
              UNLESS u delete, or messed with WinSxS
              u can delete the gdiplus.dll in RR dir, it shouldnt ever be used anyway (prob could elim from installer)
              (NOT GDIPlusWrapper.dll, that IS BEING used)
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                GDIPlusWrapper.dll
                Mitch you are a genius! I ran regsvr32 on GDIPlusWrapper.dll and now its working. I did run the installer so not sure why it didn't work correctly. Anyway, thanks for the help.
                  yes, i was about to post
                  i unregged my wrapper
                  and it did the same
                  i dont see how the registration failed, if u used the installer
                  unless U RAN the uninstall on another directory!!!!
                  like u installed it twice, then uninstalled one of them!!!
                  that would cause the .dll to be unregged!!!
                  mitch
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    I just added some debug.txt logging to identify this problem in the future
                    and a suggestion to register the wrapper
                    will be in next months build
                    and FYI, reason u get an error without GDIWrapper, is the images are PNGs
                    VB6 doesnt support PNGs (too old)
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      subscribed
                        and it did the same
                        mitch
                        Sorry I didn't realize my post was moved. I only installed once. My old roadrunner "install" wasn't from an install but rather an xcopy so I never did an uninstall. Not sure how it got into that weird state...
