RR button -> girder 4 event?
  • RR button -> girder 4 event?
    Hi
    How do I get RR to trigger an event in Girder4 when I press a button in a skin page?
    I've tried B10,0,59,61,78,"SENDKEY;a","" and hoped it would work. But Girder 4 doesn't seem to react on it.
    Girder 4 will react when I press the a button on a real keyboard, just not via VB Sendkey.
    Are there any other ways of doing this?
    Best ect.
    Henrik
    try sendkey like this
    B10,0,59,6178,"SENDKEY;{a}",""
      At least the earliest versions of girder had a command line tool called "event.exe" which allows you to send events to girder. You should see if that exists on version 4 and use the RUN or RUNQ command to send the event to girder instead of using SENDKEY -- which may not work with girder unless it's on focus or something.
      Ride Runner RR's Myspace
        Yes , event.exe is what you need...don't know if it works with v4, I would check the promixis forums...
        Sig, smig...
        Ford Flex Toshiba Excite 7.7 Install
        CoverMess - Cool Flash Covers
        FlashFlex - Flash Components for your skinning pleasure
        Mazda Millenia, Road Runner
        YouTube - Road Runner, IGO8 PC, Dashcommand OBD, Visteon HD Radio
          @MGD: Already tried that. I think Girder 4 does not capture virtual keys from RR at all.
          @Guino: Girder 4 does have event.exe, and YES, IT WORKS.
          RUNQ event.exe with parameter and let Girder learn from Girder events.
          Thanx a lot!!
          Henrik
            Well. It work. But ...
            When I press the button in the skin, it sends event to girder and girder does stuff to the nav program (the button is in the externalgps.skin) all fine,
            exept I get a "Road Runner Compatibility EXE has found an error and is exiting", and then the RoadRunner.exe in the taskmanager closes and I'm left with only RideRunner.exe
            Edit: it seems to be related to letting girder executing command parameters to the PC_Navigator8 windows buttons.
            It works, but Road Runner Compatibility EXE crashes.
            I've reverted to girder mouse clicking through the buttons...
            That doesn't activate the error.
            Henrik
              Hard to help anymore with out more info. Like what is the step by step process that your doing with those cmds.
              Next in line: RRMedia v2.0
              DFX 5.1.1 Skin
              Appstore Link
              My RideRunner Plugins
              RRMedia
              RRExtended
              DFXVoice
                Yes, I know.
                But the problem is that I forgot to make a backup before changing the cmds to simulated mouseclicks...
                Anyway the simulated mouseclicking works just as well, so no problemo.
                Hopefully, no one else rables into this presumed bug (being either related to Girder, RR or PC_Nav8).
                Henrik
                  Well, I was just asking so that if in fact the issue was RideRunner or or the RoadRunner.exe then it could be checked and fixed if problem is found so that others would benifit.
                  DFX 5.1.1 Skin
                  Appstore Link
                  RRMedia
                  RRExtended
                  DFXVoice
                    OK, I just went back and recreated the cmd's.
                    Here is the situation:
                    I have RideRunner (the february release I belive) running...
                    As navigation program I use PC Navigator 8.
                    loading External GPS skin and PC_Nav8 starts.
                    I've made a few buttons in the skin to access different buttons in the PC_Nav8 menu structure. A kind of shortcuts.
                    The way they work is by activating an event in Girder 4 that in return do a series of leftclicks with W and L Parameters targeted at PC_Nav8.
                    The crash of RoadRunner compatibility EXE seems to be activated with ANY "leftclick with W and L Parameter" targeted at PC_Nav8
                    Just pressing test in the below image activates the crash
                      just dont use roadrunner.exe, its not needed
                      unless u got some OLD program who sends KEYS
                      and if u do, get it updated
                      there isnt much code in roadrunner.exe
                      i cant tell what ur doing, dont target roadrunner, only riderunner
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Sun, Come shine my way
                      Wind, Carry me home
                      The piece of me that died
                      Will return To live again
                        @Mitchjs: errh, I don't have any problems anymore.
                        As I wrote in post 6; I found another solution,
                        but as Blue ZX3 wrote in post 7 and 9; it would be a good idea if we can find the problem so it can be sorted out.
                        So thats why I recreated the situation in post 10
                        Right now, I'm just awaiting his reaction.
                        Henrik
                          would need to know what crashes the roadrunner.exe
                          did u use girder to send win messages or keys... and who did u send them to
                          riderunner or roadrunner
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
                            As the image above shows,
                            I send "Left Click" with W and L Parameter to .... wierd, I've already explained this in post 10 with a picture of it all,
                            and directed your attention to it in post 12....
                            Am I the only one able to see both the text and the picture in post 10?
                            Henrik
                              no i see the pictures, but i dont know what all that means
                              ok, so its a windows message your sending to WHERE?
                              looks like not to riderunner/roadrunner
                              but sending a message to another program...
                              mitch
                              -Thanks
                              Mitch
                              www.rush2112.net
                              Wind, Carry me home
