Album art enbeded into ID3?
  • Album art enbeded into ID3?
    So i've been trying to find a front end actually still supported to switch to from Frodoplayer but I always seem to run into something that keeps me from wanting to switch, tried installing Riderunner however I can't seem to get it to properly work with album arts embeded in the ID3 tag and that's how I have my library set up cause that's a standard among any MP3 player out there including winamp which Riderunner uses, but I can't get it to work, I even tried the plugin for it but no go, well it partially works, but not fully, seems to only work when every file in the folder has the same album art, if each song has it's own like NIN The slip for example it doesn't, is there any way to get this to work correctly?
    2005 Dodge Magnum RT, Samsung Galaxy Tab install
    the skin that you are using has a lot to do with this,also you said that you tried the mp3Art plugin, to use the plugin is a matter of registering the dll, then use "AlbumArt" indicator, thats all, latest version has been improved and updated for RideRunner and RoadRunner.
    BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
    RRTube ==> [View/Download Youtube Videos]
    WifiMan ==> [Wifi Manager]
    RRec ==> [Audio Capture]
    If You Want To Be Given Everything, Give Everything Up ...
    Bird York -- In The Deep --
      Right now i'm using the default skin (Carwings_Dynamic) and I did register the dll and it does show up as enabled in the plugin manager.
        That's how I just added my album art, and I'm running DFX4 on RR.
          I did try DFX4 but didn't have much luck with that either, it wouldn't even build the music database actually.
            carwings doesnt use indicator "albumart", at least i dont think it does
            u have to customize now!
            -Thanks
            Mitch
            www.rush2112.net
            Sun, Come shine my way
            Wind, Carry me home
            The piece of me that died
            Will return To live again
              How exactly do I go about doing that? the thread with the albumart plugin didn't say anything about customizing, just registering the dll and enabing the plugin. Carwing does use albumarts as well, but only as a jpg in the folder, if that's what you ment by not using it.
                its done with an indicator
                someone who can skin can help you...
                but that image on the audio_player.skin and on the menu.skin, is not
                and "albumart" indicator
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  you can use the skin editor or even notepad can help,
                  i.e. open "audio_player.skin" an look for a line like this,
                  Code:
                  I,632,81,165,169,"AlbumArt"
                  RR is a great Front End, and to get the most of it, you need to understand the basics about customizing it. if you want to get this working right out of the box try another skin(you will need to go over the installation process), there are a lot of nice skins out there, not just 2 or 3, give them a try, and good luck.
                    you know what
                    J command will pickup the albumart!
                    it falls back to if no picture mentioned to use albumart
                    no need to edit skin
                    just drop mp3art, into plugins dir (to be nice in its own dir)
                    and register it...
                    done
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      and of course embed some art into ur mp3, i use ID3-TAGIT myself, it works!
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        I just downloaded/installed
                        http://www.mp3tag.de/en/
                        and that works great too... gets tags from websites and artwork and embeds
                        remember winamp dont do it, nor does it itunes, i think itunes stores art in custom format, in some artwork folder
                        -Thanks
                        Mitch
                        www.rush2112.net
                        Wind, Carry me home
