Newb question about modding a skin.
  • Newb question about modding a skin.
    Let me start by saying Iím a complete newb when comes to modding skins or anything inside RR. I run DFX4.0 because it looks cool in my car and it was easy for me to customize within the program itís self. A HUGE thank you to whoever spent the time to make this so user friendly!
    Anyways, I have a goal and was wondering if I could get pointed in the right direction. Im not sure how hard or extensive it will be, but I figured I would give it a shot.
    Simply, I want to be able to click a button on the ďhome screenĒ of my DFX skin and have it open a program, very similarly to how it opens Iguideance in a new screen and sizes it correctly to fit, while still retaining the ďMenuĒ button on the screen. The program I am interested in is created by Innovate Motorsports, and is called Logworks 3.0. Hereís a link: http://innovatemotorsports.com/suppo...orks3Setup.exe
    I use this for monitoring my wideband 02 sensor and some thermocouples, and would really love to integrate it into my current skin, but donít even know where to start. Is what I am asking difficult? Is there an example someone can show me that might help point me in the right direction? I donít have a ton of programming experience, but Iím a quick learner! Iíve searched around a bit and really donít see much on this, unless I am looking in the wrong places.
    Anyways, any help or recommendations would be greatly appreciated.
    Cheers,
    -Alex
    Welcome, to the great hobby.
    Simple description of DIY, would be to first copy a skin file that already has an embeded application area defined (DESTINATOR_7.skin) and rename to ie.Logworks.skin then use this code for a button:
    Code:
    "LOAD;logworks.skin;;<full path to prog exe>;<window name of running prog>"
    Sample:
    "LOAD;logworks.skin;;C:\Program Files\Logworks\Logworks.exe;The Logworks"
    BTW, if you haven't already looked at the Skin Commands.txt located in the documents folder, I'd suggest glancing thru that as its the "skin manual" for RideRunner.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
      Code:
      Sample:
      Thanks for the tip! That worked beautifully; opens the program from the button I want. Is there a way to make the actual window appear embedded without the frame? I used winspector but Iím afraid I might be doing this wrong. Hereís the code Iím using for the button in DFX4.0:
      LOAD;LOGWORKS.SKIN;logworks;C:\Program Files\LogWorks3\LogWorks3.exe;!Button
      Thanks!
        Cool, going to check this out for embedding Capture!
        Ampie Case
        256 MB DDR2 PC5400
        Xenarc 700TSV - VGA Monitor
        Intel D945GCLF Motherboard
        M2-ATX-HV
        2005 Honda Civic
