XMPCR with RideRunner not working
  • XMPCR with RideRunner not working
    I have tried about everything I can think of. The XMPCR works with Roadrunner and SatAmp but not with Riderunner. I get no signal so I am guessing it is not interfacing. I used the installer, loaded the hot fix and registered xmcomm.dll.
    Has anyone got an XMPCR to work with Riderunner? What steps did you use to set it up?
    Thanks, Brian.
    Mac Mini, XP pro SP3
    if u use the installer...
    all modules will update
    Roadrunner shouldnt be on ur pc at this point...
    if its in another directory... dont try to register xmcomm.dll
    you will have 2 different versions!!!!
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      just install RiderRunner with the 4/1 installer
      set comport in rr.ini if not already set
      thats it there is no other that has to be done
      just dont register anything... its all done by the installer
      -Thanks
      Mitch
      www.rush2112.net
      Wind, Carry me home
        I did use the installer
        Maybe I am missing something. Here is what I did:
        1. Uninstalled Roadrunner.
        2. Installed Riderunner using installer (double clicked on RideRunnerSetup.exe)
        3. Installed the Riderunner update.
        4. Ran RunMe1st.cmd (because XMPCR didn't work).
        5. Uninstalled Riderunner and reinstalled.
        6. Ran registry cleanup tool.
        When you say run the installer do you mean run msiexec.exe from the command prompt to install Riderunner?
        Thanks for getting back to me.
          I will try again
          OK, I will uninstall everything and try again.
          Thanks.
            1. UNINSTALL ROADRUNNER (if it was installed by some installer)
            2. INSTALL RIDERUNNER (make sure u select xm option)
            thats all...
            im assuming u saved all you're .ini files? rr.ini
            if not u need to reconfig
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              msiexec.exe HAS NOTHING to do with riderunner!!!
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                oh, u know, u can turn on debugging, and XMdebugging...
                and read the debug.txt
                its kinda what i call SELF HELP
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  Still no luck - must be SP3
                  Reinstalled:
                  1. Uninstalled Riderunner
                  2. Rebooted
                  3. Installed Riderunner.
                  4. Installed hot fix
                  5. renamed xm.down.png to xm_down.png to fix error
                  6. configured xm comm port.
                  still no luck. I will look at some of the SP3 secuity settings. SatAmp and XM Satellite softeare works ok.
                    Already Tried turning on debugging
                    Already turned on debugging and didn't find anything.
                    When I find the problem I will post it for others.
                    Don't take anymore of your time with this.
                    Thanks for the help.
                      u want me to, i wrote it
                      sp3 prob has NOTHING to do with it
                      turn on XMDebug :
                      in RR.ini: (or use rrconfig)
                      debugmode=true
                      debugfresh=true
                      xmdebug=true
                      lets see your debug.txt, rr.ini
                      (attach it to post)
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        log
                        4/21/2009 8:14:08 PM: Executing: XM
                        4/21/2009 8:14:09 PM: XM---> XMActive:
                        4/21/2009 8:14:09 PM: XM---> XMActive: Not powered on (yet)...
                        4/21/2009 8:14:09 PM: Que Exec: True, xm.skin, "ONSCREENCHANGE", False
                        4/21/2009 8:14:09 PM: Que Exec: True, xm.skin, "ONSOURCECHANGE", False
                        4/21/2009 8:14:09 PM: Leave Exec: False, xm.skin, ONSOURCECHANGE, False
                        4/21/2009 8:14:09 PM: Enter Exec: False, xm.skin, , False
                        4/21/2009 8:14:09 PM: Que Exec: True, xm.skin, "ONSONGSTART", False
                        4/21/2009 8:14:09 PM: Leave Exec: False, xm.skin, ONSONGSTART, False
                          thats NOT enough
                          ATTACH the whole log & rr.ini
                          debug.txt
                          rr.ini
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
                            Here it is
                            Here is the debug log
                              ok, now i know whats up
                              the COMPORT never opens....
                              now why you only do 1/2 of what i ask, is beyond me...
                              what is xmport=? in rr.ini?
                              -Thanks
                              Mitch
                              www.rush2112.net
                              Wind, Carry me home
