Sorting playlist by Title or Artist
  • Sorting playlist by Title or Artist
    I just upgraded my RR installation after leaving it alone for over a year and I have a problem. I have a player skin that sorts my mp3's by title or by filename (artist-title). It's worked for years but now it doesn't since the new version was installed.
    To do this, I set the "Title" in Winamp to be %artist%. Then here are two commands I have in my ExecTBL.ini file:
    "SORTARTIST","ACTIVATE;Playlist Editor||SENDKEY;^+2||PLFORMAT;%ARTIST% - %TITLE%||RELOADLIST||SETVAR;SORTEDBY;0"
    "SORTTITLE","ACTIVATE;Playlist Editor||SENDKEY;^+1||PLFORMAT;%TITLE%||RELOADLIST| |SETVAR;SORTEDBY;1"
    My player.skin has a button like this:
    B,78,347,82,86,"SORTTITLE||SWITCHBUTTON;5>>SORTART IST||SWITCHBUTTON;5",""
    Why would this stop working? When I'm in the Winamp Playlist editor and press shift-ctrl-1 or shift-ctrl-2 it sorts properly. Just that the changed list doesn't show up in RR.
    Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
    well... i did a sort in winamp, and reloaded the list in rr
    and it showed up
    make sure u enabled METADATA READING support in winamp
    option 1 or 4
    now i dont know how to set those key sequences in winamp... dont see any options like that
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      ALSO for "ACTIVATE;Playlist Editor" you have to be using the CLASSIC SKIN or MODERN
      does NOT show up when its in BENTO
      -Thanks
      Mitch
      www.rush2112.net
      Wind, Carry me home
        I'm using a skin I made myself a couple years ago. What's the specific reason why one skin would work and not others?
          WINAMP SKIN!!!
          and u didnt answer my question, on how to make winamp use that sequence
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
            Ah, yes, I'm using the Classic Winamp screen in version 5.34.
            If you're referring to what keyboard commands do the sorting, they've been around for a long time. Maybe newer versions don't do it anymore? They're documented in About Winamp | Keyboard Shortcuts:
            Code:
            Ctrl+Sh+1   Sort Playlist by Title
            Ctrl+Sh+2   Sort Playlist by File Name
            Ctrl+Sh+3   Sort Playlist by File Path and Name
            Ctrl+Sh+R   Randomize Playlist
            Ctrl+R         Reverse Playlist
            If I highlight the Winamp Playlist and press these keys, they work fine. If I have the Playlist set to show in Winamp, I can see it display for a second when I press the RR command button and it doesn't look like it has changed order. So maybe it's an issue with the sendkey not being received by the playlist editor rather than the refresh not working?
            [EDIT:] Hmm, wait a sec... I just noticed that the Winamp playlist window says "WINAMP PLAYLIST" instead of "PLAYLIST EDITOR". Maybe Winamp has changed that heading at some point which would make the ACTIVATE not work! I'll test this and be right back...
              damm, im on 5.52 and those keys dont work
              i can resort with clicking in there...
              i did check the windows names, and PLAYLIST EDITOR is NOT avail, unless in classic...
              but that is the problem... the window name, cause when i sort it in winamp, and reloadlist, it works
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                What I see.. WA v5.31
                using wa classic skin,which is the one your supposed to use, Playlist window title is "WINAMP PLAYLIST", but using Modern skin, the win title becomes "PLAYLIST EDITOR"
                Next in line: RRMedia v2.0
                DFX 5.1.1 Skin
                Appstore Link
                My RideRunner Plugins
                RRMedia
                RRExtended
                DFXVoice
                  Thanks for all the help! It's working great now. It WAS the Winamp window title that had changed. I'm very surprised to hear that the sorting keys don't work in 5.52 (why would they take them out?). Have to make a note to never upgrade to that version.
                    Or maybe mitch forgot to take off his blinder's...IDK though, I have no reason to update from my current verion.
                    DFX 5.1.1 Skin
                    Appstore Link
                    RRMedia
                    RRExtended
                    DFXVoice
                      i like the NEW version!
                      (im sure keys there, or programmable, im just blind)
                      same reason one should upgrade to new version of RR
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
