Door Open Pop up
  • Door Open Pop up
    Hi Guys
    well i do remember this is an old idea...But never the less
    Can some gurus make a plugin for RR that can pop up a small pic with the appropriate door open when 1 of the car door is open...
    This way no matter on which screen you are on .. the moment a door is opened the pic of car with its door ajar pops up....with a voice alert ( muting music if it was playing ) :-)
    ( just a small add on toy for the RR )
    also still a better idea if some 1 can go a step further to control the LOCKING / Unlocking of the doors with voice activation
    Thanx
    vicky
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
    Not all cars have sensors in each door/trunk/hood, and a system saying what door is open, is as I see it spesefied to what kinda car one have.
    For instance, in a BMW, the signal is run through the IBUS, and one need an IBUS controller to catch that signal.
    I would guess that never cars have something simmilar, or at least they should.. But programming something that universal is quite wast I think.
      With my New Age skin these are commands sent to RR that will trigger this type of thing.
      "CarDiag1" = Passenger Rear Tire Is Low
      "CarDiag2" = Passenger Front Tire Is Low
      "CarDiag3" = Driver Rear Tire Is Low
      "CarDiag4" = Driver Front Tire Is Low
      "CarDiag5" = Check Engine
      "CarDiag6" = Gas Low
      "CarDiag7" = The Brake Fluid Is Low
      "CarDiag8" = The Oil Pressure Is Low
      "CarDiag9" = The Passenger Door Is Open"
      "CarDiag10" = The Drivers Door Is Open"
      "CarDiag11" = There is a problem with your charging system
      "CarDiag12" = The engine is overheating
      "CarDiag13" = The Driver Seatbelt Is Not Buckeled"
      "CarDiag14" = The Front Passengers Seatbelt Is Not Buckeled"
      "CarDiag15" = The Rear Right Passengers Seatbelt Is Not Buckeled"
      "CarDiag16" = The Rear Left Passengers Seatbelt Is Not Buckeled"
      "CarDiag17" = Your Head Lights Are On"
      "CarDiag18" = Your Key Is In The Ignition"
      I use joypad software to send the commands and the existing switches in my car to trigger joypad. Search the forums for joypad to see how to use it.
      New Age Garmin - Skin for RR
        Hi well thats a nice skin...pretty well done
        but i am using DFx 4 and want THESE GR8 functions in it ... If some 1 can do the need full it will be nice
        2.6 GHz; 1 Gb Ram
        120 Gb Laptop HD
          Hi Thanks
          for the update
          But can you pls be more expressive and tell me in details as how do i have to go about it
          ( and I am pretty good with electronics but programming is WAY to far from me )
          2.6 GHz; 1 Gb Ram
          120 Gb Laptop HD
            Hi ThunderStick
            well i have gone thru the site for JOYPAD and also Ver 3
            But can u pls help me with this
            as how do i connect the doors for the screen to pop up with the relevant pic and voice prompts
            ( i can do the wiring ... if u can detail me )
            2.6 GHz; 1 Gb Ram
            120 Gb Laptop HD
