RR 05-01-2009 Release
  • RR 05-01-2009 Release
    New May 2009 Release
    Some highlights:
    • Images in custom lists: (we'll post some samples)
    • WMP (Windows Media Player) support
    New XM/SR Communications libraries (continous improvement)
    A bunch of small bug fixes this time...
    and a updated SkinTool!
    I want to thank Blue for all his work with RRConfig/Skintool and core codework in RR. Thanks to Guino just to have this program, and the nice addition of images in custom lists and the NEW WMP support.
    -Mitch
    Edit:
    The release is now available on HERE.
    There are sample Custom Lists (used for testing) HERE (Please unzip ALL files into a test skin folder)
    There's also THIS PLUGIN to provide Equalizer for WMP and for video playback (on most XP/Vista systems)
    Thanks for your support,
    Guino.
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = bug fix
    ^ = Note
    5/11/09
    + SkinTool Reload ExecTBL button & Updated docs
    # Seekbar not hiding in DVD menus when using MPC
    5/09/09
    + HD RADIO "TUNEUP" / "TUNEDOWN"  how the heck did we miss that...
    # Built-In video not resuming
    # "RoadRunner" compatibility exe crashing
    + DDGUID setting (Used with WMP/DirectDraw)
    5/07/09
    * Updated Sirius and XMComm (supports channel wrap arounds)
    + *.m3u in cachedir save/restored for HORM
    + Inital Windows Media Player support (ACTIVEX)
    # ErrScrn texboxes not hidden on inital display
    4/28/09
    + Images in Custom Lists
    + "CLSETIMG" skin command. see skin commands.txt for details
    4/23/09
    # fixed picviewer inital view, not loading files in picspath
    4/19/09
    # FMPresets directory is created if doesnt exist, when using "FMPRESET;xxx.fm" to save
    # Reloadscreen not re-centering screen vertically when used on a menu screen
    + SDK ErrScrn method, allows calling of the new internal error screen
    + SkinTool: "ONCOMMANDINVALID" now translates to "Command Not Executed: xxxx" in live debug log
    * "ONCOMMANDINVALID" que'd right behind cmd that was invalid, instead of appending to the end of the que'd cmds
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    first! wooho
    lol i was just here checking for if there was an update, thanks!
    New Project in the Works
    Previous Worklog here
      Yay!
      Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
        thanks!! waiting for the new release!
          what do you mean by "WMP support"? r we ditching winamp ?
            Pretty sure its just because WMP support has been requested.
            Live mp3Car Facebook Chat
              haha.. I'm not dumping anything I'm aware of.. we're just adding support for more players. WMP is a weak one in my opinion, but some find it lighter/better so now you can choose what you like.
              Ride Runner RR's Myspace
                thanks a lot, now to update my plugins...
                BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
                RRTube ==> [View/Download Youtube Videos]
                WifiMan ==> [Wifi Manager]
                RRec ==> [Audio Capture]
                If You Want To Be Given Everything, Give Everything Up ...
                Bird York -- In The Deep --
                  Does the plural in this sentence mean that foobar support might be coming in the near future? Please!
                  98' Honda CR-V
                  http://www.superbluecrv.com
                  *OBDMPG, the RR OBD Plugin*
                    Actually I have considered foobar as an option for a very long time, but it lacked a stable/reliable interface for higher-end languages, so it was just not worth the effort before. Having said that, I've just looked at the latest stable version and their new COM server version seems to work really well from VB6 -- which means it should not take much effort to make foobar as an available player for RR now.
                    EDIT: It took quite some effort, but it's done and it seems to be working very well.
                      Just updated to this release of RR and now when i open it it takes the volume to 50% and its locked there... If i set it to 100% in my windows volume control and open RR it goes to 60% for a second then to 50%. Once opened i can minimize and adjust the volume in Volume Control again. As soon as i restore RR it snaps the volume back to 50%.
                      I tried renaming the RR folder then doing a fresh install again and still the same issue.
                      Any ideas anyone?
                      Oh yea, and I'm using the BMV2 skin.
                        bratnetwork, how about some information in your post
                        what OS?
                        this release means RR 5/1/2009 right?
                        could post a debug.txt too.. that would tell us alot initially about your setup
                        first i would turn off fadevolume, fadeinvolume=false in rr.ini
                        turn off fadeinvolume=false in rr.ini and see how it goes
                        -Thanks
                        Mitch
                        www.rush2112.net
                        Wind, Carry me home
                          I dropped the (image in) custom lists example files in a test skin - now what? Do i just call those individual .skins with a button command? or are they supposed to work toguether somehow?
                          OLD SYSTEM (DEAD)
                          Intel D945GCLF2 Dual Core ATOM
                          Lilliput 7" 629GL 2008 LED Backlight
                          BU-353 USB GPS Receiver / iGuidance / IGO8
                          M2-ATX Power Supply
                          RideRunner Front End / Various Skins
                          Windows XP SP3
                            in those example skins, look closely at the third line, has an extra parameter at the end
                            Next in line: RRMedia v2.0
                            DFX 5.1.1 Skin
                            Appstore Link
                            My RideRunner Plugins
                            RRMedia
                            RRExtended
                            DFXVoice
