riderunner phone help
  • riderunner phone help
    hey all,
    Im just looking into getting the phone working in RideRunner with lsx void skin however it just says "trying to connect" when I click on it, even though its paired up in windows ok, I have also tried it without being paired with no joy.
    can anyone shed any light on this?
    p.s sorry if this is posted elsewhere Ive had a look but no joy.
    cheers
    do you know which phone app your using. There are a number out there.
      Ah this could be the issue, I have no idea what phone software is bundled in with LSX Void, does anyone know? Or if now can anyone advise of one that I can use with this skin?
      Many Thanks
        ok, ive tried using .net Bluetooth Mobilephone Plugin however this doesnt show in the plugin manager, anyone have any suggestions?
          a screencapture would help, but to me sounds like is freefone,if this is the case, there is a config. ini file in the same folder where freefone is, take a look at that.
          BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
          RRTube ==> [View/Download Youtube Videos]
          WifiMan ==> [Wifi Manager]
          RRec ==> [Audio Capture]
          If You Want To Be Given Everything, Give Everything Up ...
          Bird York -- In The Deep --
            right ive found the application and it is freefone however its not showing up in plugin manager, i think im missing something simple here?
              freephone is quiet old.. it is not a plugin i think..it is just an external app embedded in RR. try to follow the threa on the .net Bluetooth Mobilephone Plugin..it uses bluesoleil and is more recent.
              there is a solution on the thread in case it does not show up in the plugin manager
                freephone is too old to have the plugin manager code so it wont show up. If .net mobilephone doesn't show up see post 77 of the thread. It basically says you need to register it with a /codebase. If you have problems just post them in the thread and I'll try to sort them
                good luck
                  good luck
                  Great cheers, thats got that registered now, however I dont know how to get that into my skin now, im assuming this is a skinning issue? anyone able to help on this one?
                  cheers
