Can't disable ID3 Browsing
  • Can't disable ID3 Browsing
    Hi! Love this software, been using it for long. Uppgraded to latest version from an old old one and now I can't disable ID3-tag browsing. I untick the box in RR config s/w and check that it is "False" in the RR.ini but all my browsing is still ID3 and not filename. How can I fix this?
    Best regards L. Kull
    it works here...
    i unchecked id3 browse...
    and USING CARWINGS, RR May 2009
    when i browse, my file name was 03 - Weathered (test).mp3
    and what shows iis:
    Weathered (test)
    which is correct
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      try to set this in RR.INI:
      titlesafter=
      Ride Runner RR's Myspace
        yea.. if i didnt want it to drop the "03 -" part
        any case, the option works
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          It still does NOT work for me
          Tried 3 different skins (Carwings + 2 others), and on 2 computers.
          Can it be that I use an older version of Winamp then the latest? (5.35)
            The winamp version should not matter as long as it's at least 2.9x, however, if you have setup winamp to read the metadata ON LOAD, then ID3 may still show up on the playlist. I'd suggest you check your rr.ini to verify for duplicate settings for the ID3 options -- if you have more than one line, the last ones will prevail. If you don't want any ID3 showing up, you should turn off metadata ON LOAD (in winamp), then set in RR.INI:
            useid3=0
            showid3playlist=false
            showid3browse=false
              useid3=0
              showid3browse=false
              I DO want ID3 for playlist but not for browsing. I only have one line in RR.ini regarding id3 browsing and its showid3browse=false, still browsing is done w/ ID3. But not w/ old RR from 11 april -07.
              What can be wrong here?
                This is definitely weird... it works fine here (just switching showid3browse), are you sure that your files are not already formatted and maybe RR is only changing the "casing" of the names (set by the noformat=false/true option) ?
                I would like you to post 3 things so I can better help you:
                1-a Screen shot of RR's display of a folder
                2-a Screen shot of Explorer's display of the same folder on "1"
                3-a zip of your rr.ini
                  Yes I'm sure, I get this on 2 different computers so I must be doing something wrong in the RR software, not hardware, windows or winamp.
                    love, that image looks right!
                    it working!!
                    look at the setting
                    titlesafter=-
                    if u want all the stuff before the "-"
                    set
                    titlesafter=
                    mitch
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      it working!!
                      look at the setting
                      titlesafter=-
                      set
                      titlesafter=
                      mitch
                      Just realized that my self I never really bothered to read what the "titlesafter" was but after reading, I changed to "nothing" and it works like I want it.
                      Thanks for all help and very good support from the developer(s).
                        that was the first thing I asked you to try...
                          Damn, missed that post. I'm so sorry.
                          Best regards L
