winamp line-in plug in help..
  • winamp line-in plug in help..
    is there a way to get the hd radio to play on all my speakers with the "line-in" plug in? I can only get it to play from the front left and right, I re-installed the plug in numerous times and read the readme files. is there something else that I need to check or is this because of the sound card I am using? thanks.
    i sure there is a OUTPUT plug in for winamp, for it to send audio to out speakers...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      never thought about that, thanks. I'll check it out.
        I know that with the line in plugin you can specify how many channels you want it to record/playback -- that is the line that you setup in RRConfig, so you could try changing it too.
        Ride Runner RR's Myspace
          The line-in plugin only specifies how many channels to record (eg. "line://dev=1,title=Radio,srate=44100,bps=16,nch=2" in RRConfig).
          As Mitchjs said, outputting to multiple sets of speakers would be the job for an output plugin. Oddly enough, my setup sends the sound to the back speakers by default when it only has a stereo input.
          One sec...Hmmm...search, search. Ah, here we are. I've answered this before. Short answer: enable the DirectSound Output plugin.
            never mind, its my sound card. some how "line in" is disabled when in a 5.1 setting. It was hooked up to the "mic in" before. thanks
              I take it you got it working? If not, the only way I could get mine to play on the front and back is with this program.
              http://software.muzychenko.net/eng/vac.html
              Mike
              My Rides:
              '03 Vibe GT!
              My AED GA!
                no I did not, thanks! I will give this a try
                  keep in mind u dont need VAC
                  nor want it
                  just the small app that comes with it
                  here
                  http://software.muzychenko.net/audiorepeater_ks_155.zip
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    also, the VAC409 package has a olderaudio repeater v1.20
                    it might actually work better then the 1.55
                    it in the VAC409.zip download
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      I installed audio repeater to my desktop to see how it looks, how will I get this app to start all the time? do I have to open it manually everytime I need to use it?
                        it has command line options to u can completely automate it
                        and RR can Run is for you
                        work out the comand line, its documented in his help file in the vac409.zip
                        test it... and then i think u would add it ad a "run;" command
                        someone can help... or by the time u post the cmd line ill read skintools
                        i know i work on RR, but dont know it as well as others
                        -Thanks
                        Mitch
                        www.rush2112.net
                        Wind, Carry me home
