RR 06-01-2009 Release
  • RR 06-01-2009 Release
    June 2009 Release.
    Not much new here, but some minior bug fixes / adds
    quiet month...
    Thanks again to Bluezx3 and Guino!
    I started some inital work on a unified plugin installer
    its INNO based... but it will provide plugin developers a good starting point
    more on this soon
    EDIT:
    This version also supports up the Foobar2000 18 band equalizer (will require a skin with 18 EQ sliders).
    The Install and Update are available on www.nisuautomotive.com
    Thanks,
    Guino.
    EDIT2:
    It appears the first "update" version posted had the old 5-1 EXE version in it, that's been fixed now.
    EDIT3:
    Using the installer is the best way to "update" not only does it contain the newest code, but also the newest support files,
    which ARE NOT ALWAYS in the "binary update.zip". The Installer will not overwrite ANY existing configuration files.
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = bug fix
    ^ = Note
    6/3/09
    # vars that contain multiple commands now work, and also work via exectbl
       example: SETVAR;MYCMD;AUDIO++PAUSE   and $MYCMD$ is exec, now both AUDIO||PAUSE exec
    5/30/09
    + Bounds checking for 1st paramater in "SC" definitions (custom lists)
    5/15/09
    + "TAGTITLE" - HD Radio title supported (updated skin commands.txt to refect tagxxx support in xm/sr/hd)
    5/15/09
    + Initial Foobar2000 Support
    5/13/09
    * Reminder screen does not halt RR functions ans is now a 15 second overlay
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    №1 up!! good job!
    RUSSIA - WINER!!!
      NISU Website still says May 1 update.
      CAR: 2007 G35 Sport Coupe 5AT
      HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
        Didn't read did you?
        Next in line: RRMedia v2.0
        DFX 5.1.1 Skin
        Appstore Link
        My RideRunner Plugins
        RRMedia
        RRExtended
        DFXVoice
          It's up now.
          Ride Runner RR's Myspace
            Thanks to all of you.
            Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
              Thanks as always.
                Thanks!!!
                CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
                MediaLaunch for RR
                Online Check for RR
                Locker for RR
                  Just downloaded and installed the update....RR reports it's still the old version? Date modified on RideRunner.exe is 5/13. RR Notes.txt is 6/4 though.
                  MediaLaunch for RR
                  Online Check for RR
                  Locker for RR
                    when u run, rr?
                    defined installed? you used the INSTALLER RIGHT?
                    that looks like, the update .exe package... dont use that
                    im not 100% sure, g had a chance to update it, looks like its a bit messed
                    in anycase u shouldnt use it
                    cause its not always complete, and it assumes ur updatiing every month
                    the installer is safe, and keeps u updated with ALL core files
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      Hey I just ran the installer. Looks like it has the latest version
                      thanks,
                      MediaLaunch for RR
                      Online Check for RR
                      Locker for RR
                        no prob, Ill get the right file to G
                        but just use the installer, i spent many hours on it
                        and it will not overwrite any .ini file... or existing skin files (except carwings)
                        and it gives u the latest XM/SR/HD radio too... if i have any updates to it
                        -Thanks
                        Mitch
                        www.rush2112.net
                        Wind, Carry me home
                          thanks guys. great stuff as always
                            I updated this morning, and found this version to be rock solid. Fantastic job RR Team!
                            ATTENTION FELLOW CAR PC ENTHUSIASTS, POWER ACOUSTIC = CAR PC KRYPTONITE!!!! AVOID AT ALL COSTS!!!!
                            To my adoring fans, No my Toyota's gas pedal didn't get stuck! Instead I saw you crossing the street and decided to floor it! Unfortunately, I MISSED!!!
                              I've been live in the truck for a few days now, i'll install this version and let you know how it goes, thx again for everything RR devel team.
