RR and Garmin Trouble
This topic is closed.
  • RR and Garmin Trouble
    I am having a hell of time getting garmin to stay on top when embedded in RR.
    I have my window name set to Garmin Mobile PC and have also tried CDP_WND_FIELD
    nothing seems to keep Garmin on top of RR when I press a play button or try to overlay the OSK.
    Wht the hell am I doing wrong...this used to work great...
    Dummy problem.. read last post
    New Age Garmin - Skin for RR
    Contrary to other applications, Garmin mobile PC create a new window each time you change screens. So, it means RR probably make the first screen topmost, but if you switch the screen by pressing the settings button for example, a new window handle is created, so RR don't make it topmost. I have seen this problem as I am in the process to disable the exit and minimize button for my own interface I am building and I had to hook the click on these buttons and I have to reapply the hook each time another screen is shown.
      I did have this trouble in the past though. When I made the overlay for the OSK it worked great.
      Is anyone else having this trouble?
        i'm using GMPC all the time with RR v10.10.08 and it embeds great - no issues changing screens ...
        The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
          THat's probably it. I am using the latest RR. 6.01.09
          LIke I said it has worked great in the past up until recently
            no changes to anything related to embedding apps.... that im aware of... its not roadrunner vs riderunner
            are u using the built in dimmer??? if so, turn if off..and see
            (prob not, but worth mentioning)
            -Thanks
            Mitch
            www.rush2112.net
            Sun, Come shine my way
            Wind, Carry me home
            The piece of me that died
            Will return To live again
              Seriously though, that is the only change to my setup in a long time (rr version change). Probably over a year.
                Now when in the external_gps.skin if I click on music control buttons at the top of the screen GMPC ends up behind RR, but if I go back to the main menu then back to the external GPS screen then it reappears.
                Same with trying to use the overlay plugin. If I try to overlay the OSK on top of GMPC then I lose GMPC.
                  Sorry one last post, I have tried this on three different PCs. My desktop, a PC with a fresh install of windows and my carpc.
                  Same issue on all 3.
                    are u using the GMPC overy script??? (ElcosMenu.exe)
                    that runs outside of rr you know
                    why not post some screen shots, since im a bit lost
                    like i dont know what "music control buttons at the top of the screen GMPC" really means...
                    maybe put a example .skin to gether for me
                    you know, i downloaded GMPC setup as trial...
                    set GMPC on Carwings overlay works... kinda...
                    its a bit buggy... prob needs work
                    specially cause it might be looking for roadrunner windows
                    and maybe slipping past the compatibilty.ex
                    i might need to set it up in skin ur using...
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      Are you using this ?
                      I have it working with the latest RR and LSXVoid 3. Haven't tried any other skins though.
                        Here is a vid clip of what is happening.
                        Press the OSK button then press it again to close the OSK, OSK dissappears and so does Garmin.
                        At the end of the vid I pressed the next track button at the top and GMPC dissapears.
                        The buttons at the top are part of RR, not the overlay.
                          OH yeah, yes I am using elcomenu for the overlay. I know this is not part of RR. But it still screws up when just trying to press a button outside of the application window.
                            Wow do I feel dumb now....
                            Sorry for the trouble.
                            I was missing the application frame in the skin...
                            DUMB DUMB DUMB...
                              DING!
                              i was gonna ask for the skin file u know
                              looks nice btw
                              mitch
                              -Thanks
                              Mitch
                              www.rush2112.net
                              Wind, Carry me home
