Feature Request ...
  • Feature Request ...
    If possible can I add a request for one of the upcoming RR releases please ...
    It's a small one for the label display code ... we have the "LEFT", "RIGHT", "CENTER", "SCROLL" .. etc commands associated with the label command, but could you add a command that will center label text horizontally within a label box ... say a "MIDDLE" command which would center the text in a label box both horizontally and vertically ?
    Thanks in advance ....
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
    "CENTER" is centralized horizontally. I only see the benefit to center it vertically if you're displaying multiple lines of text -- is that the case ? (If you're displaying only 1 line in the label, then you can just align the position of the label in the skin and it will always be that same position)
    Ride Runner RR's Myspace
      yep that it ... i have a popup box with a large sized text lable capable of displaying multiple lines of text ... but they always display at the top of the box / screen. A facility to center vertically would just enhance the ability to display text centered in a large textbox.
        I'll see what I can do.. the standard label object doesn't allow for any kind of vertical centering..
          I was thinking that might be the case ... but I have every confidence in your coding abilities guino !
          Thanks again ...
            I've added some new label options for the next release.. which include the request on this thread.
              nice one ... many thanks guino ...
