RR 07-01-2009 Release - Available NOW
  • RR 07-01-2009 Release - Available NOW
    Update 7/17/09:
    The July release is finally available on the site.
    We apologize to the delays while we were trying to get everything tested and ready, including the config.
    The install is now available on www.nisuautomotive.com.
    There will be NO UPDATE package for this release -- this is because of the considerable amount of changes/files on this version, so you can update using the installer (no need to uninstall previous version) OR install fresh.
    Reviewing the latest install, there is a known issue with RRConfig, where it will show the options for Foobar200 and iTunes but it shows no box to set the path for these players -- if you use either of these players you have to open RR.INI and set the playerpath setting MANUALLY.
    There are 2 threads that you should read/view if you haven't done so:
    Audio Player Choice
    Video/DVD Player Choice
    Below is an updated list of changes...
    Thank you for your support,
    RR Dev Team.
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = bug fix
    ^ = Note
    7/16/09
    # Fixed RADIOMUTE command
    7/14/09
    + Fennec support added (Browsertype=2) -- only for embedding on standard browser screen.
    7/13/09
    + F definition accepts variables for flash movie parameter
    + SETFLASH command added to switch/remove SWF movie from screen
    7/12/09
    + LABEL: "osversion"  returns sting of operating system, ie "Windows 7", "Windows XP"
    + RideRunner.exe now containes a UAC Manifest (when run on machines with UAC enabled, it will request elevation)
    + Automatic disable of MSMPEG2ADEC filters during the use of MSVidRR (Dolby license is only for Microsoft applications)
    7/9/09
    # Hidemouse=false hiding mouse on DVD playback (reorganized internal code to control hide/show of mouse)
    + Improved detection of End of Video playback (RR Core)
    ! Completely new Video Player Core, including Video Playlist Support
      Supported Players; MPC(Media Player Classic), WMP(Windows Media Player), VLC(Video Lan Client 1.0.0 reqs ActiveX)
      									 MS(Microsoft Directshow video player[part of DirectX])
    6/26/09
    + Added LABEL FORMATTING; scroll "ONCE" label option (see NEW Skin Commands.txt)
    + Added LABEL FORMATTING; "VCENTER", "VHCENTER" and "MIDDLE" alignment options (see NEW Skin Commands.txt)
    + Added support to \n (end of line marker) for labels
    6/17/09
    # DL list type "LST" got altered into a type "SNG" causing selection issues in plugin manager
      (cleaned up code, so that only "SNG" type would have its ID3 tag processed) ("LST" now is generic)
    + the up/down code for select of item in plugin manager DL (thanks carputer1)
    6/10/09
    + Added "ALL" option for IMG definition and LOADIMG and LDIMG commands
    6/5/09
    ! Rewrote internal browser support, IE7, IE8, FF3 tested
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    FF3! VLC! And here I go thinking I'll soon be done tweaking stuff on my setup...
    Awesome work as always.
      Looking forward to it. Video is the one thing that I have had a problem with. Not that it needs to work while driving.
      CAR: 2007 G35 Sport Coupe 5AT
      HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
        can't wait to get my greasy paws on this 1 just what i need to finish up lol.....
        Riderunner / Genesis
        Wifiman_NET:Version 1.0.0
          text centering ... yipeee .. thanks guino !!
          The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
            guess its too late to ask for fennec support for web browsing. It really is the best touch friendly browser out there. Very glad to hear the video and dvd received an overhaul. Nice job guys.
            UGH mitch stop posting before its available you tease!
            Live mp3Car Facebook Chat
              You actually may want to give FireFox a try. Then install the "Grab and Drag" plugin. It allows you to use firefox just like the iLists. You do not have to use the tiny slider on the right, just grab the screen anywhere and drag it to scroll up/down & left/right.
              My Fiero Build Thread
                Yea i have grab and drag and it works well.. but fennec devotes 100% of its window size to the webpage. It looks like it was made to be embedded basically.
                  Wow, great job guys. Video playlists? Excellent! How it's going to work?
                  Worklogs: 08 Sequoia Platinum Carputer (In Progress!)
                  Skin: MetroSex on the Beach preview
                  07 Infiniti Fx35 (done!) & 06 Infiniti M35 (gone...)
                    This is an initial support, don't expect too much out of it.. but basically works the same as an audio playlist -- just place it in video_player.skin and you'll be able to view/list the videos on the playlist, browse through them with up/down etc and play the one you selected directly without going to the video browser first.
                    Ride Runner RR's Myspace
                      nice, very nice, can't wait ....
                      BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
                      RRTube ==> [View/Download Youtube Videos]
                      WifiMan ==> [Wifi Manager]
                      RRec ==> [Audio Capture]
                      If You Want To Be Given Everything, Give Everything Up ...
                      Bird York -- In The Deep --
                        VLC! Yeah!
                        Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
                          Hope it's not too much longer so I can start my new fresh install
                          Keep up the great work!
                            Grab and Drag doesn't appear to work with FF 3.5 yet.
                              ^ Really? I'm sure I installed it the other day and it worked fine :/
