RoadRunner not interfacing with winamp after clean install of Win7
  • RoadRunner not interfacing with winamp after clean install of Win7
    I had RoadRunner running great on Win7 RC but reinstalled with the latest RTM build I could get hold of and it's now broken. I reinstalled flash and winamp and after a hiccup where RR gave the error 'Unexpected error; quitting now' at startup until I'd launched it once as administrator, everything seemed like it was going to work. But when I go to play music in RR, nothing happens. It transfer me back to the music page but the track list remains empty and winamp doesn't start playing anything.
    I initially used winamp 2.95 but tried 5.13 (which was what I'd had with the previous Win7 install). Both installs were from installer still sat on the local disk from when I set up Win7RC.
    Anyone know what's going on?
    Switched to the latest RideRunner and it doesn't have this issue. But it has other issues...
      Never heard of a "perfect" software ... in any case, RR must run with admin rights or some things just won't work, that goes for all: NT, 2000, XP, Vista, Win7...
      Ride Runner RR's Myspace
        That isn't the problem here though. The older RoadRunner still wasn't talking to WinAmp even if I ran it as administrator. The newer RideRunner can talk to winamp fine even if I don't run it as administrator. Very wierd.
          I also experienced problems after updating to Win 7 RC , It took several re-installs of RR, finally ran the installer in compatibility mode and things seemed to work, same with DFX4. Things are pretty much working now, but a few quirks here and there, considering going back to XP now that there is a new voice recognition plugin.
          TruckPC - gutted, being used for test setup
          BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
          BlazerPC - Nexus 7 with Timur's USBROM
            its not wierd.. its quite logical.. many improvements to RideRunner since, RoadRunner, including communictations to WINAMP
            use RideRunner, and all will be fine...
            on WIN7/(vista), set up the short cut to run as admin
            or turn off UAC
            -Thanks
            Mitch
            www.rush2112.net
            Sun, Come shine my way
            Wind, Carry me home
            The piece of me that died
            Will return To live again
              also no need to RUN the RideRunner installer in compatibility mode
              its already UAC Aware
              now... DXF4, is a messy installer. i prob wouldnt use that...
              that skins needs a big time refresh...
              prob if u run dxf4's installer as admin, it be ok
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                True. But this is the exact same build of RoadRunner I was using successfully in the Win7RC install. Although thinking about it I've got a feeling I had this exactly problem when I was first setting it up then. I wish I could remember how I fixed it .
                The jury is still out on whether I'll switch to RideRunner. I'd coded up some nice improvements to RoadRunner to work with a custom skin (multiple variations on gps and video skins to enable you to move around in the UI and still see the video/gps and easily get back to the full view). I stopped using it when I needed a bug fix in a newer RoadRunner and found the code structure had change so much that my (somewhat invasive) changes were extremely hard work to port). But I was thinking of maybe starting over and re-adding that support. But that means I'm stuck with the old RoadRunner. Or alternatively I can scrap the fancy picture-in-picture style skin idea and build a new skin idea I've had that I think shouldn't require new support in the exe .
                  maybe u can do all ur mods, in a Extension plugin... not sure what you got going, but there is just so many performance improvements in RideRunner...
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    Maybe. I've been away from the RR scene for a couple of years so it's all new to me .
                      once u install RIDERUNNER, the winamp.dll object is registered, and the old one becomes obsoleted by com. and if the com interface changed (it prob did).... the old .exe wont be able to use it
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        Ok, so I should expect the old roadrunner to be broken at this point. That doesn't explain why I couldn't get it to work before I installed RideRunner though.
