music not resuming after hibernat on RR (is killing me)
  • music not resuming after hibernat on RR (is killing me)
    its few months I have this problem and I remember it happened after I reinstalled my windows, before it was working fine.
    XP SP3 with enabled EWF on it and RR and winamp 5.13 are installed on my USB flash drive. when music is playing and I restart the PC, it starts playing from where it was left. but when I hibernat, it never resumes music:-( before I hibernate pc, I remove winamp playlist so whenever I turn on pc winamp is clear:-( I know before hibernate I have to remove USB but the thing is that when I make hibernate point without USB plugged in, whenever PC loads hibernate point, winamp disappear in 1 seconds and I have to run winamp again manually.
    has anyone had something like this?
    There is nothing impossible in the world :-)
    Did you follow the RR HORM sticky notes?
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
      i had this problem before, go into rr config, think there's something about "RR hibernation aware" something along those lines, make sure its NOT checked. Sorry to be so vague but I don't have it installed on this computer so I can't check it for sure.
        I found that check box but it didn't make anything better:-( and yes I did follow the RR horm sticky but when I click on Hibernate button on RR, after few seconds it gives an error that says ALERT! HORM DRIVE LOCK FAILED, HIBERNATION ABORTED. and nothings will happen after this error :-(
          Okay, It was giving me error because I had RR and Winamp on USB drive so when it was trying to dismount the USD it couldn't. i uninstall them and reinstall them on C now and it does the job without any error but it still not resuming music I change the settings many many many time in last 6 hours but RR doesn't make any HORM folder in my USB ... please heeeeelp
            try running the OS off C
              Did you set "hormdrive" in RR Config? If that's not set, it won't create/copy rr data into the usb drive.
              Also, you CANNOT run RR or winamp, or any program for that matter, off the USB drive you designate as the HORM drive. If any programs are running off the HORM USB drive, RR will not be able to lock and dismount the drive.
              Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
                UGH!!!
                DEBUG
                DEBUG
                DEBUG
                should i say it again?
                ok
                DEBUG
                -Thanks
                Mitch
                www.rush2112.net
                Sun, Come shine my way
                Wind, Carry me home
                The piece of me that died
                Will return To live again
                  posting rr.ini and a debug of ur sessions
                  and thats after you do everything in the horm instructions
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    there is not any software installed on USB anymore... it does resume music but it doesn't make any folder called HORM in my USB. I can see when I close RR, it makes a resume.ini file in its directory but it doesn't make a copy of that to my usb. i tried different USD drive as well, but no luck:-( I attached files and I changed rr.ini to rr.txt because it wouldn't upload INI file. :-((((((
                      there is no hibernation/resume sequence in the debug...
                      so cant help ya
                      i assume i already made your hibernation point...
                      so... boot pc (its a technically a resume), use riderunner for a sec, power off your computer... also, if your power supply doent send proper signals to the OS, RR will never know your powering down)
                      you do know once u create hibernation point, you DONT hibernate anymore
                      you power on and shutdown...
                      its on the shutdown.. that RR will create HORM files
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        is that can be because of SP3? Okay what I will do is that uninstall the XP SP3 and install XP SP2 and I will post the result here tho.
                          I just installed XP SP2 and the main problem is solved now :-))))) :-D but there is a little issue there. when I turn off PC via RR, everything work flawlessly but when I use PC power switch or windows shutdown menu, it wont resume music. so it seems windows just cut off RR without notify RR so RR can not save settings.... any idea? had anyone same issue?
                            windows shutdown menu, should give RR enough time...
                            all the information is in the debug.txt !!!!!!
                            you can see if it made it though bits of shutdown.. or if it was forced to exit
                            one thing for sure dont mess with the windows default shutdown times (i forget the key)
                            just to give u a faster shutdwon
                            -Thanks
                            Mitch
                            www.rush2112.net
                            Wind, Carry me home
                              i can't have debug.txt cause ewf is enable there so after shutdown there wont be any debug there. but I know my windows has problem for sure!!! I installed ewf on XP pro. what I will do is that download XPe trial version from microsoft website and give it a try... i will post the result here tho.
