Using a Slider behind a Scrolling Label?
  • Using a Slider behind a Scrolling Label?
    Hi,
    is it possible, to use a Slider (SONGPOS) behind a scrolling Label? Behind a static Label works fine, but behind a scrolling would be finer...
    One Way for me, i could use the "SCROLL-ONCE" from RR 7.1.09 - During the scroll it shows only the Label and after that it show the Slider behind, like a static Label...
    Is this possible?
    With already released versions this will not work because of the way the scrolling label works -- it grabs the image of where it is positioned when it loads, and uses that image from then on. But I just had an idea here that I want to try before I say it can't be done (for future versions)..
    Ride Runner RR's Myspace
      Ok, I tried my idea and it worked really well, so on next release Scroll labels will work over Buttons, Indicators and Sliders -- even made the scroll labels use a little bit less memory
        Guino... can this be done as well?
        Hey Guino, can this new "idea" be used to show an indicator or image inside a button area as well? I know a blinking indicator will work, but I also have indicators that are images that will not show up within a button area. Such as the icons on the dfx main menu for instance.
        My Fiero Build Thread
          Hey g, since you're looking at labels , any chance you can me them blink?
          Kinda like indicator images w/ the ":B" on it, but for labels?
          i.e.
          L,...,"BYIND;SHUFFLE;<<=SHUFFLE","LEFT:B"
          Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
            You want an indicator/image to show "Overlayed" on the button right ? to where it shows the image on top of the button regardless of the ON/OFF/DOWN effects modifying the button ? I don't think the same principle applies (because there's no "object" for indicators), but I don't see why we couldn't take care of it one way or another..
              @JohnWPB: would it be enough to have an Indicator "Modifier" (like the :A one -- maybe a :O) so that the indicator is "Overlayed" on top of everything else on the skin ?
              I'm just analyzing the options right now.
                i.e.
                I'll see what I can do..
                  That sounds like it would might be a plan... and man is it about time to have this actuall added. I tried on several occasions to do it but all the imagery was making my head spin just a bit.
                  Next in line: RRMedia v2.0
                  DFX 5.1.1 Skin
                  Appstore Link
                  My RideRunner Plugins
                  RRMedia
                  RRExtended
                  DFXVoice
                    I just improved support for indicators over buttons (and even sliders), I remember this would have been a pain in the arse with the old sources, but now that the code is a lot more organized it was actually not too bad to make it work, so John you can try it out to see how it works for you (If you do it before the release, I can probably fix/tweak it more if needed).
                      Very Cool! I will update my SVN and give it a try....
                      Thank you!
                        Ok, just built the exe and when I load my DFX skin, there are no image indicators on the main menu. Is there a new way to display images with the modifications?
                        This is my code to show the icon next to the button on my main menu page:
                        PHP Code:
                        "FILE;$SKINPATH$$MAINBUTTON2Gfc$:A"
                        the "$MAINBUTTON2Gfc$" is of course a variable that contains "whatever.png", so I can keep the icons matched up with the dynamic buttons.
                          PHP Code:
                          I guess I have to check it out.. it worked for standard on/off indicators, so I figured it would work with others.. but let me double check things and I'll let you know.
                          EDIT: I think I forgot one small detail only.. I'll adjust, test and let you know.
                            Ok, try it now.. should work from what I tested.
                              WooHoo!!!!!!!!!!!!!!!!!!!! That did it! This is something I have wanted to be able to do in RR for SOOooo long! I had to design the main menu of my skin around the fact an indicator could not show up under a button.
                              Just about every skin has all sorts of workarounds for this as well the exec labels, putting indicators next to a button ect ect.
                              Thank you, Thank You, THANK YOU!
                              Liquid Smoke is going to LOVE this As we were working on something some time ago, and couldn't find a way to do it... till now
