Retrieving Info From External App To RideRunner
  • Retrieving Info From External App To RideRunner
    hi all
    im wondering if there is a way of retrieving info from an external program to rr
    the app is m4-atx configuration program
    its a simple vb app
    i want to get the voltages textboxes into rr labels
    i can get their class id's , texts and everything with autoit window info
    so im guessing there must be a way for it to be read by rr
    is it possible?
    thanks in advance ,
    madboy
    HeadUnit : Car-Pc | Processor : JBL MS-8 | Front Stage : Woofer - Mpyre 65M , Mid - Dayton RS100-4 , Tweeter - Tang-Band Ceramic 25-1719S | Subwoofer : Hertz HX250D | Amps : A/D/S PQ10 , Hifonics Olympus XI , SPL AB03445 | Wiring : Sommer , Neutrik
    If you can read it somehow (i.e. autoit), then it is definitely possible to make a (extension) plugin to display the info in RR. If you have the source code for the vb6 application then it would make it a lot easier, but if you already know autoit and can read the values from the app, you just need to make a script that reads the values say every second and sends them to RR using the sample scripts attached.
    Ride Runner RR's Myspace
      thanks guino ,
      ill try to request the source from the m4 guys but its unlikely they will give it away
      i don't know autoit that much hehe
      and its been a while since ive codded with vb :\
      how do i read the values from within autoit? i went over their documentation and i can see only how to control the "controls" , the question is how to retrieve their "text" not write to it
      first ill try to contact m4 guys and lets see what happens
      i hope that if ill get the source someone will be able to do this
      thanks again
        i believe when the m4 first came out the released an sdk which allowed for plugin type creation. I remember i was gonna make a RR extension plugin for the m4.. but the reliability issues at the time changed that plan lol
        Live mp3Car Facebook Chat
          well i have no problems with the m4 so far
          any chance you track the sdk ? i couldn't find it..
          still nothing for mini-box guys..
            You can embed their application...
            After messing around with it, I was able to find out the window title.
            its "M4AtxTitle"
            "LOAD;m4.SKIN;M4AtxTitle;c:\Program Files\Mini-Box.Com\M4ATX\M4AtxTray.exe;M4AtxTitle",
            As a test I created a skin file called m4.skin, which embeds the tray application.
            I have also created a skin file which uses larger text and a black bakground.
            Just unzip these two files into the the c:\Program Files\Mini-Box.Com\M4ATX\ directory.
            Choose the skin "Big(custommx3)"
            I have attached a screenshot.
            Also you can edit the mbs file with notepad and change colors. You can also change the BMP to whatever you like. I know its not a plugin, but at leasts it will embed.
            2011 Nissan Frontier SL
            AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
            OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
